Wireless modem wireless router connection
Currently Active Users: 1490
Discussions: 200,931, Posts: 2,379,163, Members: 246,297
Old January 8th, 2008, 09:00 PM   Digg it!   #1 (permalink)
Send a message via MSN to cheezo
My brother recently got a wireless modem from verizon. I dont know much about it except he said it connects via usb. They said at the verizon store that it worked off of cell towers. My question is this, is there a way to connect it to a wired/wireless router or any way to connect to it through his computer so that he will have a wireless network throught his house so his laptop will be connected to the net as well.
cheezo is offline   Reply With Quote
Old January 9th, 2008, 09:49 AM     #2 (permalink)
A hero in training
GroundZero3's Avatar
A model of the device would be a big help
GroundZero3 is online now   Reply With Quote
Old January 9th, 2008, 02:20 PM     #3 (permalink)
THE Gimp Clown Fish!
nemowolf's Avatar
http://www.verizonwireless.com/b2c/s...eless+pc+cards
Verizon Wireless UM150 USB Modem
Verizon Wireless USB720 Modem
Verizon Wireless AirCardŽ 595U USB Modem
Verizon Wireless USB727 Modem
Not that many out there ...
Old January 9th, 2008, 05:50 PM     #4 (permalink)
Banned
Keymaker's Avatar
Send a message via ICQ to Keymaker Send a message via Yahoo to Keymaker
EDIT-READ WRONG!
Yes, post the model please.
Thought you wanted to connect to the house network on the road with a laptop.
A router just plugs into the modem's output jack (WAN connection) then the desktop gets plugged into one of the routers LAN ports 1-4 and the laptop can share the connection wirelessly with the router. A router is used to share a network connection with more than one computer. Wired or wirelessly.
Crap! I forgot that the modem gets the signal from an antenna. So there may not not be a jack.
What you could do then is bridge the USB connection to a router. I think..
Keymaker is offline   Reply With Quote
Old January 9th, 2008, 06:19 PM     #5 (permalink)
It is a usb720 modem.
Old January 9th, 2008, 09:36 PM     #6 (permalink)
nemowolf's Avatar
Originally Posted by Keymaker View Post
EDIT-READ WRONG!
Bridgeing the connection out from his laptop would be the only way as i doubt there is a device that takes a USB modem ... Can he return for a PCMCIA card?
http://reviews.cnet.com/routers/top-...-31890358.html
Old January 10th, 2008, 02:37 AM     #7 (permalink)
Banned
Keymaker's Avatar
No, I meant a network bridge in the desktop. When you plug the USB modem into the computer; software that comes with it will more than likely create a network adapter in the network adapters section of the control panel. I think you could bridge that to the desktop's network card and therefore use a router from that.
I know you can bridge a PCMCIA card to the NIC of a laptop. My bro did this to a Sprint mobile card and shared that connection out from the laptop to a desktop. So this is the same idea.
Wireless connection to wired router? JohnE. Networking and Internet 9 June 27th, 2007 08:12 PM
need a new wireless modem/ router dominique Networking and Internet 7 May 31st, 2007 01:33 AM
wireless router/modem. It wont connect to net. Wishmaster Networking and Internet 18 January 12th, 2005 07:02 PM
ISDN modem to wireless router problem bavaria34 Technical Support 7 July 20th, 2004 06:02 PM
DSL Modem and Belkin Wireless Router Thunderchild Networking and Internet 1 April 23rd, 2003 06:04 PM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
