a 32-bit lancard in a 64bit pci slot
Currently Active Users: 1450
Discussions: 200,931, Posts: 2,379,160, Members: 246,297
Old January 11th, 2008, 08:20 AM   Digg it!   #1 (permalink)
Banned by everybody
Ultima's Avatar
Send a message via ICQ to Ultima
Hey guys,
at work we have a somewhat older server, which works fine except for the
onboard nic's, those have been wrongly flashed and no longer work, not even after reflashing and all that can be tried.
It has 2 64bit expansion slots, and I seem to recall that a 32bit pci card will work just fine on a 64bit slot, it should just downgrade it's speed and make it work, shouldn't it??
It's an HP Compaq Proliant DL360 G2, dual P3 1.4Ghz, 4Gb ram and 2 x 36.4Gb scsi3 15k rpm.
thanks for any info.
AMD Phenom II X3 720BE @ X4 920BE 3.6Ghz
4GB DDR3 1333, Dual 4870 1GB in Crossfire
2 x WD Caviar Black 640GB @ raid 0
Ultima is offline   Reply With Quote
32-Bit Vs. 64-Bit LetMeKnow General Tech Discussion 36 March 20th, 2008 03:01 AM
PCI-E video card Issue Battousai_CR Technical Support 5 January 10th, 2008 08:18 PM
PCI-E Video Card HW Install Issue Battousai_CR General Tech Discussion 1 January 10th, 2008 02:46 AM
HELP !! A bit worried !! 8800GTX SimD1978 Graphics Cards and Displays 7 January 8th, 2008 08:05 PM
Question on PCI-E 2.0 YummyIeatNoobs Graphics Cards and Displays 3 January 3rd, 2008 12:21 AM
Is It Just Me? (2872)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
