Thread: help on ??wifi router??
April 15th, 2008, 08:28 AM #1Junior Member
- Apr 2008
- 7
i hav an xbox 360.
what kind of router can i use to wirelessly hook into my houses wireless setup. i was looking at the NETGEAR RangeMax Wireless-N but am not sure if that recieves wi-fi signals. could some body show me some sort of wi-fi mrouter that would work.
April 15th, 2008, 08:32 AM #2
You will need to look at a model that supports bridging mode. Just look through the specifications of each router and they will tell you if it supports bridging or not.
Posting the model of the router you have would be a big help
April 15th, 2008, 11:32 AM #3Junior Member
- Apr 2008
- 7
here it is hope it helps
Netgear RangeMax Router
Model: WPN824NA
April 15th, 2008, 11:39 AM #4Junior Member
- Apr 2008
- 7
April 15th, 2008, 12:22 PM #5
Please stop creating multiple threads to ask for help about the same issue!
April 15th, 2008, 02:46 PM #6
If i remember correctly that router doesn't support bridging at all.
April 16th, 2008, 12:31 PM #7Junior Member
- Apr 2008
- 7
wifi bridging
Whats your opinion on the netgear and linkysy gaming routers for playing online games like COD4, TCR6 Vegas 2, and Halo 3.
Which one of these would be a better choice.
Which of these can i buy and then just configure everything through my xbox 360.
And does the connectivity to xbox live depend more on what wifi bridging device i hook to my 360 or the one that is sending the signal out?
http://www.linksys.com/servlet/Satel...=2661900349B01
http://www.linksys.com/servlet/Satel...=4757740536B01
http://www.netgear.com/Products/Adap...rs/WGE111.aspx
April 24th, 2008, 02:03 PM #8Junior Member
- Apr 2008
- 4
Linksys Wireless-N Gigabit Gaming Router
http://www.linksys.com/servlet/Satel...=3266539789B05
April 24th, 2008, 03:34 PM #9
The search feature in this forum works fantastic...
http://www.xbox.com/en-US/support/co...compatible.htm If any router isn't on the list, that doesn't necessarily mean it won't work, but I would have my doubts in stability.
http://www.microsoft.com/windowsxp/u...etup/xbox.mspx
Gaming routers are BS hype if you ask me.
Okay, let me say why...
I have a wrt54gl flashed with DD-WRT.
(Mouth full) I have two computers gaming on it and a third and fourth surfing the net and at times using Skype. Even before I flashed the router it worked flawlessly right out of the box. I'm sure there are other non "gaming routers" that will perfom just as well.
If you use p2p application like Limewire or Bittorrent, whatever. Kiss your network goodbye. Install DD-WRT and look up scripts for DD-WRT that will reduce the active connections in the router. Skype is p2p, but isn't like file sharing.Last edited by Keymaker; April 24th, 2008 at 03:46 PM.
Ammo Lan (w Monitor and Wifi Router)
By MrBurritoMan in forum PC ModificationReplies: 10Last Post: September 7th, 2004, 01:39 AM -
WiFi
By 802.11g in forum Security and Privacy IssuesReplies: 20Last Post: September 1st, 2004, 10:56 PM
Bale and Casey Affleck Watch Monsters University Online It's hard to believe, but Dumb & Dumber To is really going to happen. At least, until the next stumbling block totally destroys it again....
