View Poll Results: what type of internet do you have | |
telstra
|   | 0 | 0% | |
dodo
|   | 0 | 0% | |
aapt
|   | 0 | 0% | |
iinet
|   | 0 | 0% | |
or net gear router
|   | 0 | 0% | |
other
|   | 2 | 100.00% | Free Scan: Update Your PC's Outdated Drivers to Optimize Performance
June 12th, 2008, 10:21 PM
| need nat help click my thread
hey guy,s ive made thise thread to help with nat problems just give me a buzz and ill help you as a meen buzz send me a thread with your problem and i will hope to fix it for you  |
June 13th, 2008, 07:05 AM
No offense, but if your spelling and punctuation is HORRIBLE, are you sure you can help with technical issues  |
June 28th, 2008, 06:21 AM
I srsly doubt it, lol  JK ... but since you'v created this thread i'm gonna ask you a question right away.
For some reason i can't port forward and peer to peer "games/application" totally lag out, with my awesome latency of over 10000.
allways been un-answered, probably stay that way.
Its been said it had to do with my nat wich i don't know to much off, though it can be configured with my router/modem, and since thats probably the cause of my trouble i hope you can give me some advice on making port forwarding work.
Btw, i suspect it has to do with my isp... because i have a dynamic ip wich is said to be made static if you don't want any trouble with your router.
August 7th, 2008, 05:29 AM
Xbox 360 Nat Strict - Help!
Hi, I can connect to xbox live fine no problems, but the NAT comes up as strict, so this means its harder to find games on live etc, so im trying to get a open NAT and i wonder if you could help me....
im connecting it via a ethernet cable to my laptop and my laptop is wirelessly connected to my "BT Home Hub"
Another thread was posted about this
Xbox Live and NAT Issues
Basically it says to do the following i did all the way up to "Devices" part
where you find your XBOX 360 ip and then click on configure.. but it does not show up, does anyone no why ? or can tell me another way how to get my NAT settings to open, without spending £60 on a XBOX wireless adapter.. And im also using a BT HOME HUB
thx |
August 7th, 2008, 02:29 PM
HAHAHA, My internet is a netgear router ... No offense but i dont think you present yourself as anyone who knows what they are talking about to those that know. How about you give us more to work with then just a single post and your assumption were going to believe you about your "skillz." |
August 10th, 2008, 09:21 AM
| HAHAHA!!!
He didnt even reply once  . |
August 19th, 2008, 11:23 AM
Hi, just found out that I need to set up NAT for my database to work. I have been trying to look into doing this and I am totally confused. Is there any chance you can help me set NAT up?
Thanks, |
August 19th, 2008, 02:06 PM
| Quote:
Originally Posted by jeaneq Hi, just found out that I need to set up NAT for my database to work. I have been trying to look into doing this and I am totally confused. Is there any chance you can help me set NAT up?
Thanks, |
You really should start your own thread, this one is like the red-headed step child of threads. Your going to want to include more information then you have provided like what database your working with, why it needs NAT, and what NAT your working with as Network Address Translation may or may not have anything to do with what you think NAT is. |
August 19th, 2008, 02:21 PM
| | "she does what she does"
| Quote:
Originally Posted by JacobSijsma He didnt even reply once  . | Well, would you have replied if that was the kind of welcome you received? Yes, this spelling and grammar was a mess, but he was trying to be helpful. He should have received some direction and pointers without being bashed on his first attempt to post here, especially from members who have been here a while.
__________________ When life hands you lemons, make lemonade. But when life hands you a load of crap, don't make anything.
Trust me on this one. |
August 28th, 2008, 04:03 PM
Hi,
I have problems with Vuze, opened ports 6881-6889 TCP and UDP and still no luck.
Thanks,
Lime U. |
