Join TechIMO for Free!
Currently Active Users: 1162
Discussions: 182,853, Posts: 2,184,730, Members: 225,653
Old June 13th, 2008, 01:34 PM   Digg it!   #1 (permalink)
once=LUCK twice=GOOD
no1_vern's Avatar
1394(firewire) networking problems
This past monday lightening struck very close to my house tripping several circuit breakers, and killing my network. It zapped 2 of my nics. I decided rather than buying new cards I would just attach a cable to my computers using 1394 ports in each of the computers.
I thought it would be a quick easy setup. I attached the cable to the ports, changed the IP settings to "IP over Fire Wire," for each of the ports and I made the IP addresses static by selecting "Use the following IP address" and entered 192.168.1.16(and 192.168.1.17). I left the Subnet mask as 255.255.255.0 then tested the network, making sure that both of them are in the same workgroup. I'm able to see both computers from the opposite side, and can transfer files between both of them using Windows explorer. Ipconfig lists the correct settings so that isnt the problem.
My problem is that neither FF 2 nor IE6 can connect/communicate from computer B to computer A. Since computer A connects to the net via DSL I need to be able to make these programs work. I have looked through the settings several times, but I cant find a way to make the internet work. In fact I cant seem to be able to set the internet for either adapter in any way.
im running WinXP/pro SP3 on A, and WinXP SP2 on B
Any help or suggestions would be appreciated!
no1_vern is online now   Reply With Quote
Old June 13th, 2008, 07:05 PM     #2 (permalink)
no1_vern's Avatar
I finally found a solution. I cleared the arp cache -
Clear the Address Resolution Protocol (ARP) cache by typing the following command at a command prompt:
arp -d ip_address
When I typed the command "arp -a " It informed me that one of the one of the IP addresses -the one I had set as the default gateway- was invalid. Once I ran the command arp -d 192.168.1.254 I had my connectivity back.
I hope this helps anyone who runs across this problem.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
1394 Networking - can't get it to work invertedflight Networking and Internet 4 November 13th, 2005 10:15 PM
External 1394 HDD to a HD set with 1394 out, can it work? videobruce Storage Related 0 October 21st, 2005 07:00 PM
Problems with Prolific 3507 firewire/USB combo drive Matt_D Storage Related 1 January 3rd, 2005 12:13 PM
Firewire 1394 PCI 2.2 matopop Technical Support 4 December 5th, 2003 06:00 PM
FireWire/1394 (what exactly is it??) Sweeper General Tech Discussion 10 September 23rd, 2002 04:11 AM
Alaska Gov. Sarah Palin Is McCain's.. (110)
Is It Just Me? (10337)
Finally!! "Male enhancement sn.. (23)
Damn the Constitution, guns should .. (98)
oil change (7)
Built a new PC, Getting Boot Failur.. (8)
Problem with partition in vista (0)
3D Pinball for Windows High Sco.. (85)
wholesale nike jordan cheap nik.. (1)
oil change (7)
Dell Dimension 4600 Motherboard.. (0)
Official World of Warcraft Thre.. (4026)
Blocking posts with Links (0)
I'm New & I need help. (0)
Built a new PC, Getting Boot Fa.. (8)
FS: IBM t42 laptop, Dell 6000 n.. (1)
Alienware PC (0)
GIGABYTE GA-EP45T-DS3R,& C2.. (0)
