Simultaneous wired and wireless LAN connections
Currently Active Users: 2218
Discussions: 200,920, Posts: 2,379,018, Members: 246,286
Old June 17th, 2008, 10:49 AM   Digg it!   #1 (permalink)
osprey4's Avatar
Can't find the answer to a seemingly easy question.
I've got an interesting situation in my office at work. I have a Cat 5 connection to the LAN, but my wireless adapter also picks up a signal from a nearby conference room. Both appear to be active.
So do I effectively have more bandwidth?
Dell Latitude D620 running Windows 2000.
Old June 17th, 2008, 12:03 PM     #2 (permalink)
Free Thinker
M_Six's Avatar
No. Your PC will use one as default (most likely the wired) and ignore the other. We usually disable the wireless in laptops used in the office just to eliminate the pop-ups about finding a wireless connection.
You can't fix stupidity.
M_Six is offline   Reply With Quote
Old June 17th, 2008, 01:35 PM     #3 (permalink)
osprey4's Avatar
With a bit more looking around, you appear to be correct. My wireless connection manager says it's connected but the packets in/out numbers are not changing.
Old June 17th, 2008, 06:31 PM     #4 (permalink)
Free Thinker
M_Six's Avatar
It'd be nice if it would work through both in a load balancing way. Although if the pipe out from the router is full, it's not going to speed anything up regardless of how many connections to the router you have.
Old June 17th, 2008, 06:41 PM     #5 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
On the upside, if your Ethernet connection failed, you have a handy backup.
http://www.ubuntu.com
LAN icon missing from network connections Aaron_8015 Networking and Internet 2 May 25th, 2008 11:23 PM
HOW?? wired to wireless to wired networking dunamis Networking and Internet 8 June 11th, 2004 10:00 AM
One Wireless one Wired eddied2b03 Networking and Internet 5 September 19th, 2003 12:17 PM
Wireless or wired naujcdl Networking and Internet 7 June 5th, 2003 06:32 AM
Is It Just Me? (2838)
Obama the Muslim (8)
Foreign voltage (7)
Print spooler problem (10)
Dept. of HS: NSA 'Helped' Develop V.. (14)
Help getting around port 80 for camer.. (0)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (30)
I need help getting around blocked po.. (0)
Virus Doctor Popup? (0)
Browsers wont load websites (0)
Dept. of HS: NSA 'Helped' Develop Vis.. (14)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Foreign voltage (7)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
