Results 1 to 5 of 5
    Jun 2008
    Singapore
    4
    Exclamation help cant get 2 wireless router connect to each other
    hi,
    help need, anyone know how to setup 2 router connect to each other and access internet from one of router, one thing is both wireless router is different brand
    pls help thanks
    mc
    Super F@D Folder
    Jun 2004
    5,091
    Let me just make sure I understand what you're trying to do. You're looking to take 2 routers and make 1 wireless network, so you can use one of those routers to create a wireless network and then use the other to use as a wireless bridge (turning the wireless back into wired) so you can hook up any number of wired devices, correct?
    What brands and models are the routers?
    -Kevin
    Jun 2008
    Singapore
    4
    Hi Kevin
    You are right, intention to do that, as now i don't have the brand of wireless router, have to go back and confirm.
    mc
    Jun 2008
    Singapore
    4
    ok i have cfm my router, main internet wireless router with modem is from singtel which is MIO Box as my another wireless router is from Asus WL-520GU
    Jun 2008
    Same issue
    I also am trying to connect to wireless routers (both WRT54G). I have a router on the first floor and I want to put a router on the 3rd floor to act as a repeater that is wired into the other router. What settings do I need on the 2nd router? Do I need 3rd party firmware or can I use what's on the routers now? Is there a certain order this network needs to be connected? Any help would be appreciated. Thx.
  1. Replies: 10
    Last Post: May 5th, 2009, 04:59 AM
  2. Using a second wireless router to connect to connect up an XBox
    By james789 in forum Networking and Internet
    Last Post: April 27th, 2008, 03:34 PM
  3. Can one connect a wireless router to a wired router??
    By Huntingdog in forum Networking and Internet
    Last Post: August 24th, 2004, 08:17 PM
  4. Trying to get laptop to connect to wireless router???
    By CraigK in forum Networking and Internet
    Last Post: June 7th, 2004, 12:00 AM
