Ethernet Cable not being read, LED lights not lit...
Currently Active Users: 1647
Discussions: 195,858, Posts: 2,327,998, Members: 241,383
Old July 26th, 2008, 05:16 PM   Digg it!   #1 (permalink)
Hey guys I have a Toshiba Qosmio laptop and I was connecting to the net sometimes through a wireless connection and sometimes using an ethernet cable. I used the wireless most of the time, but when I needed a more stable connection for things like playing online games, I plugged in. I haven't needed to plug in the cable for about 2 months, so I have just been using the wireless, which i am using right now and has been working fine, and just the other day I tried plugging in via ethernet cable to try to get a little lan party going and it did not work. I had no idea what was wrong, but I tried to plug in my own ethernet cable, the one I had been using successfully for several months prior, and that was also not working anymore. Both the lan party setup and my home setup are working fine with other computers.
When I plug in an ethernet cable in the back, none of the LED light indicators are showing up (they normally would), and my computer is not detecting a cable at all. I visited Network Connections Tab, and made sure "Local Area Connection 2" is enabled, and it is. Also my friend suggested that I may have accidentally turned on an option in power settings where it disables my connection when my battery is low, but that was not the case. Also I thought that maybe there was an actual manual switch somewhere on my laptop that disables a local area connection (there is one for my wireless that I sometimes accidentally switch), but there is none. Everything seems to look ok under the "network adapters" pull-down in my device manager.
I don't know much about these things and was hoping someone could try to help me out or give me some suggestions?
pythagorous is offline   Reply With Quote
Old July 27th, 2008, 08:06 AM     #2 (permalink)
Caveat Emptor
Rootstonian's Avatar
Well, you've checked-out some things already and that's good. For a quick check, try another cable!
Did you disable the wireless connection when going to the hardwire?
I assume you have some type of router installed ???
You could also download the latest drivers for the on-board network from the manuf. web site and install those.
Old July 28th, 2008, 07:07 PM     #3 (permalink)
thanks for the reply!
- Well I have tried several different cables, including the one that used to work, and others that are currently working with other computers.
- I also have tried disabling my wireless connection in the "network connections" tab before I tried hardwire.
- I'm using a netgear wgr614 router, but I have tried connecting directly from the cable modem to my laptop without using the router and still no good.
Um, I'm not really sure how to go about downloading the drivers. In my Device Manager, under Network Adapters, I see:
1394 Net Adapter
Intel(R) PRO/1000 PL Network Connection
Intel(R) PRO/Wireless 3945ABG Network Connection
I'm assuming "Intel(R) PRO/1000 PL Network Connection" is what I'm looking for an update for right?
Driver Date: 9/14/2005 Drive Version: 9.2.24.0
I went to the Intel site and I was able to find Intel(R) PRO/1000 drivers but none for "PL". They have like F, MF, etc...
A possibility is that the actual port might be messed up. I think my friend tried plugging in the AC power plug into my ethernet port once... is that a likely reason, and how would I go about fixing that... thanks.
Old July 28th, 2008, 08:34 PM     #4 (permalink)
Caveat Emptor
Some friend...LOL Most power that goes into a lappy doesn't remotely resemble a network port. Shoot your friend
You would have your ISP coming in and then going from some type of modem (DSL, broadband) into the WAN port of your router. Then you hard plug into one of the ports.
Probably not DHCP since your wireless is getting connection....by chance, do you have a static IP address assigned? That could be causing the problem.
Old July 29th, 2008, 01:44 PM     #5 (permalink)
Smile
Why dont you try a different ethernet port on the PC and see if that works !!!!!!!!!!!
nadim is offline   Reply With Quote
Old July 29th, 2008, 03:35 PM     #6 (permalink)
THE Gimp Clown Fish!
nemowolf's Avatar
LOL! Its a laptop. There are no other ports.
Okay, something simple that MAY be the cause is this. The last time it worked, did you have the laptop off AC adapter and running only on batteries? XP knows your mobile and in an attempt to sustain battery life will shut off certain things that are non-essential. Including your LAN and Wireless. Make sure your NIC is not disabled.
Old July 29th, 2008, 04:29 PM     #7 (permalink)
A friend of mine that looked at my laptop said it wasn't the problem so i didn't mention it, but in between when my laptop was working and now I had tried to set up port forwarding for eMule. I used this guide to try to set up a static ip: PortForward.com - Free Help Setting up Your Router or Firewall
I looked at the guide to backtrack and everything seems ok... the "Obtain DNS server address automatically" bubble was not clicked before though so I clicked it now... here is what it looks like now:
nemowolf, the same friend had checked to see if that was the problem and he concluded that it isn't. I'm not sure how to check if that is my problem though...
Old July 30th, 2008, 03:43 AM     #8 (permalink)
hey guys. I have been downloading Windows Service Pack 3 so I can do the automatic updates, and through the windows update it found a "Hardware, Optional" update for my network adapter. It is for "Intel Intel(R) Pro/1000 PL Network Connection" and it said "Windows Update recommends installing this update because the device on your computer to which this driver applies appears to be disabled". So I installed the update, rebooted my comp, disabled the wireless, and plugged in my ethernet cable hoping that it would finally work, but it's the same thing unfortunately = (. I went back to windows update and it doesn't have any new hardware updates.
Old July 30th, 2008, 01:22 PM     #9 (permalink)
Switch/ethernet card age issue
How old is your laptop? I've been having the same problem with a couple of really old laptops. I was connecting them to a 1 gigabit switch and they would work on and off, mostly off. Same problem as you would see, no lights, nobody home. I now have them going to a 10/100 bit switch (fed by my 1 Gig switch) and all is fine.
michrasulis is offline   Reply With Quote
Board LED lit, No Power, Won't boot kopfjaeger Motherboards 6 February 26th, 2007 04:20 PM
HDD led staying lit kenboyles72 Technical Support 5 January 14th, 2006 04:25 PM
led lights on tower presence06 General Tech Discussion 25 August 23rd, 2004 02:52 AM
LED lights. gentry_joey General Tech Discussion 5 January 13th, 2004 05:14 AM
Lit LED Clock????? Beemer PC Modification 46 March 10th, 2003 11:17 AM
Is It Just Me? (1447)
Palin Resigning as Governor (45)
Budget PC Build, first time - Need .. (14)
[F@H SPAM 28 JUN 09] Today's the da.. (138)
Looking for Some good PC games. (9)
Worth upgrading GFX card? (35)
build advice (19)
You guys might like this one (22)
Crap, my graphics have gone to hell (17)
4gb RAM (7)
Is this a decent gaming system??? (25)
Gigabyte 770 vs 790GX (cant decide) (7)
Toshiba Tecra A8 / Satellite pro A1.. (5)
need a laptop (5)
[F@H SPAM 28 JUN 09] Today's the day... (138)
Gaming Laptop (2)
[Seriously need help] External hard d.. (0)
Not enough RAM... (1)
wifes laptop (1)
Apple no longer using nVidia? (0)
build advice (19)
Desktop Computer on Laptop Screen (0)
Windows 7 Beta won't install (5)
internet connection is breaking (10)
please help (1)
What salary can I expect once I gradu.. (0)
Windows Product Key (5)
Weird Battlefield 2 errors (3)
ps3 connection- no video signal (1)
firefox 3.5 is slow to start (10)
Apple iPhone 3G S 32GB Unlocked (0)
Explorer page shuts down...HELP.. (0)
video card (2)
need a laptop (5)
Need Technical Expierience (77)
6 Quad/S SeriesMotherboard (0)
Trying to OC E7200 as much as possibl.. (3)
Up / down arrows jumps to bottom of p.. (7)
