Join TechIMO for Free!
Thread Tools
Currently Active Users: 2861
Discussions: 186,561, Posts: 2,226,535, Members: 230,200
Old August 23rd, 2008, 12:19 AM   Digg it!   #1 (permalink)
Question
NEED A BETTER SIGNAL FOR MY X BOX360
I AM WONDERING HOW TO GET A BETTER SIGNAL FOR MY XBOX 360. I AM ON BIGPOND WIRELESS AND MY COMPUTER IS HOOKED UP TO THE WIRELESS AND THE XBOX IS CONNECTED TO THE MODEM. ANY HELP WOULD BE GOOD.
rodent76 is offline   Reply With Quote
FREE instant scan
Old August 23rd, 2008, 12:49 AM     #2 (permalink)
Banned
jokostel's Avatar
Send a message via MSN to jokostel
Format c:/q
Confirm?
Y
jokostel is offline   Reply With Quote
Old August 23rd, 2008, 12:52 AM     #3 (permalink)
Ummmm, yeah....
First, might want to try typing in normal text, all caps like that, especially bold & colored, is usually considered equivalent of shouting when typing.
as to the problem at hand, well if your 360 is connected to the Modem, I'm guessing your talking connected via ethernet wire/cable... thats pretty much as strong a signal your gonna get. unless your using substandard cables or something is wrong with the modem (try shutting it down, let it sit for about 5 minutes, then start the modem again & reconnect the 360), or internet connection coming in from outside to the modem?
Old August 23rd, 2008, 01:09 AM     #4 (permalink)
YES i AM USING THE ETHERNET WIRE CABLE BUT IS THERE A WAY TO MAKE IT STRONGER
Old August 23rd, 2008, 01:41 AM     #5 (permalink)
by any chance your capslock of shift key on keyboard busted?
anyways, as I mentioned in my last post, if your using the ethernet cable pretty much no... its a wired signal, not gonna get much stronger than that, unless your using sub standard cabling with poor insulation or some sort of interference, OR, if the Modem is not sending the proper signal, which as I stated reboot the modem & that might fix it, otherwise might need a new modem. also if the signal coming into the place, from outside, or wiring inside house/building, might have a leak interference or something.
but assuming there's nothing wrong with any of that, then as far as wired connections go its as strong as its going to get.
only thing really to do, if by signal strength your referring to speed of the connection is to boost its speed through your ISP if they offer a higher speed connection.
Old August 23rd, 2008, 05:59 AM     #6 (permalink)
Rodent thank you so much for the friendly PM sent, didn't really need one, but oh well... some kind words sent back your way as a "Courtesy"
Originally Posted by rodent76
u dont seem too shy, shyguy. anyway i wanted help with my xbox not advice on my computer typing or anything else. you must have a lot of time on your hands. thanks for your non helping answer. NOT. and by the way that was on purpose that it was in capitals. thought you would like that.
I offered some help if your too ignorant to take the advice or help as to what may be the cause, then thats your problem.
I also questioned the typing since you Do Not Need to type all caps, its basic "common sense" & Etiquette for anyone typing in forums, that you don't need to capslock everything, as I said its the equivalent of shouting on forums, again, too ignorant to take the advice thats your problem, your going to run into many others down the road with same comments.
Old August 23rd, 2008, 06:48 AM     #7 (permalink)
thank mate for the help any way
Old August 25th, 2008, 01:31 PM     #8 (permalink)
nemowolf's Avatar
Longest distance you can run Cat5 without an amplifier is 300 feet. If your even remotely near this, say over 100 feet, make sure you buy a quality cable.
Either way, thanks for starting to correct your grammar but you missed the S in Thanks.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
no signal ocpprowler Technical Support 2 May 26th, 2008 05:20 AM
How do you get a better signal? Lasher13 Networking and Internet 4 January 12th, 2007 06:35 AM
No Signal happens...but only sometimes bcsmith Technical Support 2 November 28th, 2003 11:34 PM
WHY I DON'T SIGNAL Roy IMO Community 19 November 7th, 2003 08:44 PM
Is It Just Me? (402)
Test email notifications (28)
Politically incorrect signs at PA r.. (18)
1 internet. 1 house. 3 computer. ho.. (5)
Multiple video cards? (6)
Folderchat: The Holiday thread (102)
My COmputer is DEAD, HELP!!! it won.. (7)
Connected to LAN but unable to .. (4)
DFI socket 939 board acting up (0)
1 internet. 1 house. 3 computer.. (5)
Best computer-based A+ training (1)
disk defragmenter (3)
Kornshell Script for automation.. (1)
UPGRADING C/D DRIVE TO 250GB &a.. (4)
buying a new computer (0)
Automatic Photo Copy from Memor.. (3)
FS: Dell 6000 laptop, modded 36.. (1)
