Typically you want to configure your router while wired to it, not wirelessly, have you tried connecting via cable?
Whats the make and model of your laptop? Does the laptop have a wireless N card or is it a wireless G card?
"Whatever you want to do, do it now. There are only so many tomorrows." |
