speeding up G wireless laptop using an N wireless router
Currently Active Users: 1792
Discussions: 200,950, Posts: 2,379,449, Members: 246,312
Old December 25th, 2008, 06:23 PM   Digg it!   #1 (permalink)
I just purchased a Linksys G wireless router WRT54G2 and notice that the speed of the transmission to my laptop ( which has a G card installed in it and is in the same room as the router) averages 18-24Mbps. If I were to get the Linksys N wireless router would my transmission speed increase even if I didn't purchase an N card for the laptop?
saab123 is offline   Reply With Quote
Old December 25th, 2008, 06:47 PM     #2 (permalink)
There is a great program that I use from time to time called TCPoptimizer. It's from speedguide.net and it's free. If you want to use it with Vista, there may be special instructions.
guapo is offline   Reply With Quote
Old December 26th, 2008, 01:16 PM     #3 (permalink)
The answer to your question is "no".
Patrick is offline   Reply With Quote
Old December 26th, 2008, 01:17 PM     #4 (permalink)
cswalker's Avatar
Saab, The N router will broadcast its transmissions quicker, but it won’t help you, as your Laptop will still be stuck with its current speed. I would try and optimize your settings to get the full utilization out of both devices before upgrading. Before you do that though, does your internet connection run faster than 12Mbps? The G is rated for 54Mbps for routing data. So if you were transferring files between 2 machines connected to the wifi then you could transfer those files at 54mps in full duplex, but only if the NIC on those machines can do the same. So if you internet is. . . Say 1.5Mbps DSL. . . you’re not going to get anywhere near 54Mbps surfing.
Mecharu: Asus, E6600, 8 GB ram, 2xBFG Geforce 7950's (sli), ~2TB storage, Soundblaster Fatal1ty Pro
=== A Rain to Wash the World Clean===
cswalker is offline   Reply With Quote
Old December 27th, 2008, 09:58 PM     #5 (permalink)
A hero in training
GroundZero3's Avatar
With 802.11G there is no such thing as "full duplex" 802.11N is the first of its kind to implement a send/receive capacity.
GroundZero3 is offline   Reply With Quote
Old December 28th, 2008, 08:55 AM     #6 (permalink)
cswalker's Avatar
Thank you for the correction GZ
Old December 28th, 2008, 12:25 PM     #7 (permalink)
CS, thanks for the response. How would you optimize the g setting on the laptop?
Old December 28th, 2008, 12:45 PM     #8 (permalink)
cswalker's Avatar
you wouldn't on the laptop. Unless you want to optimize your browser for surfing.
Dropping the MTU size can help prevent Congestion in which there might be a bottle neck from your ISP
also, make sure you're wireless is on the correct channel. I think 6 is the best, i could be wrong though.
Old December 28th, 2008, 12:56 PM     #9 (permalink)
CS, I actually changed the channel on the router from 6 to 10 and this sped up the transmission to 54Mps as other networks evidentally were using ch 6. What is MTU?
Old December 28th, 2008, 05:01 PM     #10 (permalink)
A hero in training
The most successful channels for 802.11 is 1,6,11 You using 10 can actually cause more problems which i could spend about an hour on frequencies and channels. I think 6 is most soho equipment are set too. Using something like netstumber would tell you what people are using around you. I try to use 1 or 11 since most people dont mess with that stuff
Laptop doesn't stay connected to Wireless Router, Please Help! mattdriver200 Networking and Internet 31 January 21st, 2009 01:44 PM
Need Help Connecting Linksys Wireless Router to Laptop scarface245 Networking and Internet 4 November 25th, 2008 06:26 PM
One laptop sometimes can't see wireless router/DSL Modem tuser Networking and Internet 3 September 27th, 2008 10:18 AM
laptop not detecting wireless router darrell_h Networking and Internet 2 July 22nd, 2008 04:12 PM
Trying to get laptop to connect to wireless router??? CraigK Networking and Internet 7 June 7th, 2004 01:00 AM
The disrespect of Obama by Russian .. (35)
Making Health Care Worse (177)
Regular Build (7)
Print spooler problem (15)
EVGA 9800 gtx help with finding a goo.. (9)
Internet Lost (2)
Regular Build (7)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Open With ..... Win7 (0)
