Results 1 to 6 of 6
    Jan 2009
    3
    Angry Networking help!
    ok so heres my problem i have a ZyZEL P-660R-D1.....and im trying to get it to have a NAt Type 1 or 2 for my 360 and PS3.....and i even have enable UPnP but that doesent work and ideas would be nice...
    NOVA
    33,810
    46
    What exactly are you trying to do? Serve a game, forward some ports, etc
    Jan 2009
    3
    basicly all i want to do is open all my ports...if thats possible
    NOVA
    33,810
    46
    PortForward.com - Free Help Setting up Your Router or Firewall
    Search your router and it should tell you how to do it. Most SOHO routers have DMZ but they are a hit and a miss when it comes to working.
    Jan 2009
    3
    thanks ill check this out
    Mar 2007
    My own little world.
    11,764
    Hi,
    We mainly use ZyXEL routers at work, so I might be able to assist you slightly faster - as long as I can remember which version of menu that model uses...
    I think you will have a set of four (expandable) menus on the left side of the web interface. If you expand NETWORK, then click on NAT you should be able to change the NAT settings for the router. Normally you would want to use SUA, so you should click the radio button and then click "Edit SUA".
    If you are trying to enable all ports access inbound you can just change the default firewall option. If I remember correctly, I think this is under SECURITY --> Firewall --> Default Policy.
    Let us know how you get on...
  1. Help Networking please!
    By jerrygarcia in forum Networking and Internet
    Last Post: April 28th, 2005, 07:46 PM
  2. Wireless networking program that makes networking easy
    By pusspaws in forum Networking and Internet
    Last Post: October 5th, 2003, 11:55 AM
  3. Networking Help
    By EvilCrow in forum Networking and Internet
    Last Post: June 26th, 2003, 09:49 AM
  4. XP networking ?'s
    By Wombat in forum Networking and Internet
    Last Post: October 18th, 2002, 02:35 AM
  5. Help With Networking........
    By Hells in forum Networking and Internet
    Last Post: April 30th, 2002, 08:26 PM
