Are DSL Modems the Same as Cable Modems?
Currently Active Users: 2572
Discussions: 203,415, Posts: 2,407,339, Members: 248,936
Old June 17th, 2009, 04:29 PM   Digg it!   #1 (permalink)
Send a message via AIM to mastavic Send a message via Yahoo to mastavic
Hello, I hope you are well.
I have been using DSL for years, but am completely new to cable Internet connection. I am planning to switch from AT&T to Comcast and have a very, very newbie question.
I have been using an Airlink AR430W Super G Wireless Router to connect to DSL wirelessly. If I switch over to Comcast cable Internet, can I still use this same router to connect wirelessly? Is there anything else I have to do (other than order the plan from Comcast, of course).
Thanks,
Victor
mastavic is offline   Reply With Quote
Old June 17th, 2009, 04:42 PM     #2 (permalink)
voids warrantys
KarmaKiller's Avatar
Yes, you will still be able to use your router with the new connection. You'll get a new modem, plug the router into that, then you should be good to go.
Q6600@4Ghz | I7 920@4.3Ghz | E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
KarmaKiller is online now   Reply With Quote
Old June 17th, 2009, 04:43 PM     #3 (permalink)
MR Meek and Mild
Epidemic's Avatar
my cable company wants to know the mac id of the router but beyond that I think it should just work. it is IP from the modem to your router in both cases.
Epidemic is online now   Reply With Quote
Old June 17th, 2009, 04:44 PM     #4 (permalink)
Thanks for the replies!
Do I need to get a modem from Comcast? I was talking to them and they said that if I do not need to get a modem from them, I would be able to pay a bit less (essentially, I am leasing the modem from them for $3/month). Will just the router I already have be enough? Thanks.
Victor
Old June 17th, 2009, 04:48 PM     #5 (permalink)
voids warrantys
yes, unless you go out and buy a new modem yourself, you will need to get one from the cable company.
Old June 17th, 2009, 05:01 PM     #6 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
Just to clarify for anyone else that might stumble upon this thread wondering the same things.
A modem and a router are two different things. Modems can have built in routers however routers do not have the same functionality as a modem.
DSL modems are not the same as cable modems. While the might serve the same similar functions DSL modems have a totally different input connection (rj-11 i think) where as cable modems have a standard coax connections.
Broadband routers are typically standardized, meaning aside from various speeds on the lan side (10,100,1000) and various wireless signals (b,g,n) they are universal.
You don't specifically need to get a modem from Comcast themselves, but you do need to get a modem they support. The only good thing about leasing a modem is if there are issues they will replace/repair the modem, otherwise its much better to buy your own. You can probably get one of CL or somewhere dirt cheap.
RicheemxX is offline   Reply With Quote
DSL Modems - Can You Use Any One? JMHar Networking and Internet 3 July 13th, 2007 06:49 PM
Do DSL modems have firewalls? CoonDawg Networking and Internet 10 June 22nd, 2006 07:47 PM
DSL Modems aldtech Networking and Internet 7 September 21st, 2005 05:42 PM
DSL Modems phrozen_dreamz Networking and Internet 9 January 19th, 2004 05:00 PM
Dsl Modems? Linkin' Park Networking and Internet 9 April 24th, 2002 05:35 PM
Is It Just Me? (3711)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (34)
GPU upgrade from 8600 GT (9)
New PC Heavy Gaming Rig (8)
[F@H Chat]2/6/10 New thread for ya'.. (22)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
I want to buid a pc with this case (14)
Graphene transistors promise 100GHz.. (7)
Animated GIFs don't animate? (13)
Upgrading (5)
HD5870 Question (16)
[F@H Chat]2/6/10 New thread for ya' s.. (22)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Laptop - HDTV Connection Using HDMI C.. (1)
Video Format Total Solution: How to C.. (0)
How Good is This $450 MSI Laptop? (2)
wireless connectivity (0)
My 9400GT's fan is screwy (2)
