Results 1 to 9 of 9
    Oct 2006
    149
    My wireless connection never exceeds 11 mbps
    For my internet, I used to have a Netgear MA111 802.11b Wireless USB Adapter. My conenction was never past 11 mbps. I got a new adapter that on the box says "Up to 54 mbps". My new adapter is a SMC SMCWUSB-G IEEE 802.11b/g USB 2.0 EZ Connect 2.4GHz Wireless Adapter.
    With this new adapter, I'm still only getting 11 mbps. What the heck? Where is my other 43?
    My parents have their computer hooked up to the internet via cable, and theres a router there too. The router is a Netgear WGR614 Wireless Router 802.11g. It too is supposed to be doing 54mbps. Whenever I'm on their computer the internet speed is way faster.
    So...can anyone help inform me as to why I'm not getting the full blown 54mbps?
    Here are links to the actual product, in case more info is needed.
    Old Adapter: Amazon.com: Netgear MA111 802.11b Wireless USB Adapter: Electronics
    New Adapter: Amazon.com: SMC Networks SMC SMCWUSB-G IEEE 802.11b/g USB 2.0 EZ Connect 2.4GHz Wireless Adapter: Electronics
    Router: Amazon.com: Netgear WGR614 Wireless-G Router: Electronics
    NOVA
    34,840
    59
    Did you remove all the old drivers/application for the old network card? Check your wireless router admin settings to see if its set hard to 802.11B or if its set to B/G. Do you have the latest firmware installed on the router? Also what version of usb does your laptop have? If its 1.0 it wont go over 11 Mbps as that is what the usb standard is limited too
    Oct 2006
    149
    I just reformatted my computer, and reinstalled my new driver. So yes, my old drivers and etc are removed.
    I'm using a Windows XP Desktop computer. This computer is older, so I'm not sure if it has USB 1.0 or not. I'm pretty sure it has 2.0 though, most XP computers should have 2.0...right?
    I updated the driver, nothing changed.
    When looking at my setting, it says that the operating mode is "802.11g". I can't tell what my parents' router settings are because I have no idea how their connection is set up. Is there an easy way to see if their router is 802.11B or not?
    NOVA
    34,840
    59
    The usb version is based on hardware, not os
    What is your system specs?
    The router do you have any other options to set for the 802.11G part? There should be a drop down menu which says B, B/G and G. Do you have the latest firmware installed on the router?
    Dallas, TX
    12,679
    Maybe I'm missing something...What download speed are you paying for through your ISP? I'm paying a fortune for 10mbps and get maybe 8 most of the time.
    "Life is unpredictable, eat dessert first."
    NOVA
    34,840
    59
    His wireless connection to his router is only getting 11 Mbps when he has a G router and network card. This wont affect his internet connection, however something is not right if he is only connecting to the router with that speed.
    Are you using the windows wireless manager or the software for the network card? I assume for testing you have moved your laptop right next to the router.
    Light to Counter the Dim MTAtech's Avatar
    Long Island, NY, USA
    12,215
    The 802.11b standard is 11Mb maximum
    The 802.11g standard is 54Mb maximum
    Remember the word maximum. Both the card and the router are 802.11g but if your distance is too far or you have interference, the speed will drop.
    You can also check the settings on the router to assure it is set for "g" speeds.
    Conservatives: "If the facts disagree with our opinion, ignore the facts -- or at least misrepresent them."
    Oct 2006
    149
    I went to my router settings, and found the drop down menu.
    My computer now reads 54 mbps. Thanks a ton!
    NOVA
    34,840
    59
    Excellent glad you got it working!
What planet do we live on?
  1. so lemme get this right... (comparison of Mbps vs. MBps)
    By zskillz in forum Technical Support
    Last Post: July 13th, 2012, 02:26 AM
  2. Wireless LAN USB 2.0 Adapter 300 Mbps 802.11N for XP64
    By anomil in forum Technical Support
    Last Post: March 10th, 2009, 06:16 PM
  3. Wireless modem wireless router connection
    By cheezo in forum Networking and Internet
    Last Post: January 10th, 2008, 02:37 AM
  4. Wireless connection
    By Legley in forum Networking and Internet
    Last Post: January 8th, 2006, 05:32 PM
  5. MBps, Mbps, Kbps, KBps with Cable internet
    By agathodaimon in forum Networking and Internet
    Last Post: June 29th, 2004, 04:58 PM
