Problems using VoIP with router
Currently Active Users: 2237
Discussions: 200,944, Posts: 2,379,348, Members: 246,306
Old July 8th, 2009, 12:22 PM     #11 (permalink)
A hero in training
GroundZero3's Avatar
You have the ports 5060,8000-8005 ports correct?
GroundZero3 is online now   Reply With Quote
Old July 8th, 2009, 12:31 PM     #12 (permalink)
Negative... the problem is the same on all other computers. I didn't think it would make a difference but I had to try
freedomfighter87 is offline   Reply With Quote
Old July 8th, 2009, 12:35 PM     #13 (permalink)
Yes, those are the ports I have.
Old July 8th, 2009, 12:36 PM     #14 (permalink)
A hero in training
And you tried the port forward on just one machine and it didnt work at all?
Old July 8th, 2009, 12:39 PM     #15 (permalink)
No, it still cut off after 20 seconds. And it turns out I can only use port forwarding on one ip at a time for any given port. Maybe this router just sucks?
Old July 8th, 2009, 12:40 PM     #16 (permalink)
A hero in training
Old July 8th, 2009, 12:41 PM     #17 (permalink)
Oh wait, it says to use port forwarding you MUST use a static ip? would that affect it? The ip addresses match...
Old July 8th, 2009, 12:44 PM     #18 (permalink)
A hero in training
If the computer has the ip address, it shouldnt matter if its static or DHCP. They are just covering the basis that if it does get a new ip, it will break the port forwarding
Old July 8th, 2009, 01:05 PM     #19 (permalink)
Well, I tried disabling the "Send SIP Keep-Alives" option... no go. I read a few posts on the forum that said X-lite uses dynamic ports and to manually set them in the topology options.. I did... set to 8000-8005, the same ones set up for port forwarding... still no change. Apparently there are a few people experiencing this exact issue (disconnecting at 20 seconds) and there seems to be no resolution yet. Apparently certain routers cause this issue, and I have one of them. There's got to be something I can do...
Old July 8th, 2009, 01:12 PM     #20 (permalink)
Oh, now it seems to be a problem with the service according to other forums. It seems that this is happening to people even with no router, and people who've had routers for a long time and are just now starting to experience this. Only seems to happen with x-lite though? I don't know... it seems to be dependent on a variety of factors
VOIP Router Setup brandon184 Technical Support 16 August 9th, 2008 05:15 PM
New Router Problems lablkilz699 General Tech Discussion 2 November 26th, 2005 10:35 PM
Router Problems erethryn Networking and Internet 8 July 12th, 2005 08:12 AM
router problems CRoNiC Networking and Internet 1 November 23rd, 2003 06:40 PM
Router problems davidamarkley Networking and Internet 18 November 1st, 2002 07:42 PM
Making Health Care Worse (163)
The disrespect of Obama by Russian .. (17)
Is It Just Me? (2920)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (2)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
