Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
    Feb 2007
    New York
    187
    Why won't this cable work?
    I'm trying to plug a cable from my modem to my pc. I have 2 pcs. On one PC it works fine, i get online when i plug it. I switch the cable to the other pc and nothing happens. i dont get a connection. am i sticking it in the wrong hole? it was wireless before so i have never put a wired connection to it. here are the pics of the hole im trying to put it in. its the only one i see. Is that the right one? thanks.
    Nov 2006
    Portsmouth, UK
    4,159
    Yes that is the ethernet port. Is the device enabled in network connections? Have you disabled the wireless device?
    Feb 2007
    New York
    187
    thanks. the router is unplugged and i even unscrewed the wirless antenna on the pc. do i have to do something else? set it up to take a wired connection somehow? it starts to register it when it plugs in. the connection icon goes from the red x to the yellow exclamation point like it is trying to connect but it never does. this is a long cable that im running about 25 feet..
    Nov 2006
    Portsmouth, UK
    4,159
    Right so you have two PC's and one cable. On one PC the net runs fine, you move the cable to the other and you get the yellow triangle.
    ^^^ Just making sure....
    I would make sure you uninstal the wirelesss device, or better yet remove/disable it. If you right click the wired network does it pick up IP and such (networking not my strong point mabye GZ will be more helpfull).
    Feb 2007
    Springfield
    13,484
    5
    What OS is the PC running that won't connect?
    FAQ's ~ Team Stats
    My PC
    Feb 2007
    New York
    187
    i have vista
    Feb 2007
    New York
    187
    under device manager. i have
    802.11g network adapter
    and
    nvidia nforce network controller.
    do i disable both?
    Nov 2006
    Portsmouth, UK
    4,159
    No just the adapter... You are trying to use network controller.
    Feb 2007
    Springfield
    13,484
    5
    You might have to run "Network Setup Wizard" to tell the PC to use the network adapter, and not the WiFi adapter.
    FAQ's ~ Team Stats
    My PC
    Ultimate Member cksboy15's Avatar
    Nov 2008
    Columbus, Ohio, Unit
    1,427
    or he can open up the case and take the wifi adapter out (after he turns the computer off of course)
    Verizon FiOS Tier 2 Technical Support
    Feb 2007
    New York
    187
    alright. scratch this idea. the only reason i tried it was because i cant get my router set up. the hard connection works fine, but when i plug the modem into the router and then back through the computer i cant get it to work. not even on the wired connection. the power, wlan, internet and ethernet all light up on the router too. everything is lit up and plugged in like it is supposed to but no connection.
    Feb 2007
    New York
    187
    when i get to the last step of the router setup i get an error message it and says i must configure it manually. then it asks to give an ip address and a bunch of other stuff
    Feb 2007
    New York
    187
    This is the screen I get to. Is this normal? Do I click static ip
    Nov 2006
    Portsmouth, UK
    4,159
    Im afraid that image is way too small to read...
  15. #15
    Feb 2007
    New York
    187
  16. #16
    Nov 2008
    1,427
    agreed a larger image would be preferred.
  17. #17
    Feb 2007
    New York
    187
    that error message says "error not message receiver!"
    then it asks to me manually fill out my ip address and other things.
  18. #18
    Nov 2008
    1,427
    I'd suggest that you contact your ISP or wait for a network guy to find interest here.
  19. #19
    Aug 2003
    Madison, WI
    15,225
    You will need to reset the modem after switching it because it only leases out one IP address at a time (which was leased to the first item connected and doesn't get refreshed until a reset or the lease expires, which could be hours or days).
  20. #20
    Mar 2007
    My own little world.
    11,764
    Hi,
    I just want to confirm something before I start going off on a tangent...
    Your network connections should be:
    WAN --- Modem --- Router --- Switch --- Computer. (Sometimes the Modem, Router and Switch can all be done through a single device, but this depends on your hardware and the function/s they can do)
    Also, just out of curiosity, would you happen to be using one of these:
    Linksys by Cisco EtherFast Cable/DSL Router with 4-Port Switch BEFSR41
    (Only asking as I thought I recognised the screen from another thread)
  1. Replies: 1
    Last Post: June 6th, 2009, 08:58 PM
  2. Can't get Belkin Easy Transfer Cable to work
    By ND4SPD in forum Technical Support
    Last Post: December 27th, 2007, 12:47 PM
  3. n00b question... Is RG6 Coaxial Cable proper for Cable Internet??
    By ChestLick16 in forum Networking and Internet
    Last Post: December 21st, 2005, 02:20 AM
  4. Replies: 7
    Last Post: May 1st, 2005, 10:33 AM
