Extending my Wireless signal...  | |
October 3rd, 2009, 11:58 AM
I have bellsouth dsl running through their 2Wire modem/wireless router. The upstairs in my house get's an excellent signal. Downstairs is hit an miss. Is there a way i can extend the range and strength of the signal?
I tried sticking the thing downstairs but then the upstairs signal was lacking |
October 5th, 2009, 08:34 AM
| | A hero in training
Are the antennas on your router removable? |
October 5th, 2009, 10:29 AM
There are no external antenae |
October 5th, 2009, 11:44 AM
| | A hero in training
Well you have four options
1)Look into a MIMO router which are supposed to give you greater coverage
2) Buy a router that allows you to add on a different antenna
3)Buy a wireless extender
4) buy an access point run a long cat5 cable to give you the coverage you need (I dont recommend this) |
October 11th, 2009, 06:01 PM
you thought about Powerline Home Networking?
If practice makes perfect and nobodys perfect why practice?
October 12th, 2009, 10:03 PM
I gave it some thought. I saw a review on it and it seemed like a strong solution |
October 13th, 2009, 06:49 AM
| | He who is Nude.....
From what I (and my colleagues from my last job) have found out, using the electic circuitry to link separate locations will only work if it is on the same "circuit" - so if you have a circuit for the power upstairs and another for the power downstairs, and you want to one network point on each, then it won't work....
If you were to flick the switch in the fusebox for one power circuit and they both went out, then you can use that circuit to run the network over....
(Just my £0.02)
__________________ I've seen the light... It was green, flashy and attached to a Network Interface Card... Whenever someone says "You can't miss it" I invariably do... |
October 14th, 2009, 04:22 PM
Linksys used to have a wireless extender for 50-60 bucks. You'd plug it into the wall, it detects your wireless signal and re-broadcasts it.
__________________ How come Sour Cream can expire? |
