AT&T High Speed Internet WIFI Issue
Currently Active Users: 2064
Discussions: 200,919, Posts: 2,379,053, Members: 246,287
Old October 31st, 2009, 05:33 PM   Digg it!   #1 (permalink)
lablkilz699's Avatar
Send a message via AIM to lablkilz699
Just got AT&T high speed internet. I installed it, it works great, connected on ethernet but wireless doesn't work. I can connect to the wifi network, but pages don't load. Im on a mac, OSX 10.5 if that matters. The wireless light is lit up, its clearly functioning, just not sure what is a little off. Nothing connects btw...other computers (macs), iphone, etc.
I was looking through the network settings in system preferences and it says connected but "airport has a self assigned IP address and may not be able to connect to the internet."
Im assuming that has something to do with it but no idea what that means really, anyone know how to fix this?
thanks
Macbook Pro 15"
23" Apple Cinema Display
lablkilz699 is offline   Reply With Quote
Old October 31st, 2009, 06:07 PM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
thanks
Have you entered the security code for the WIFI network your on? Most of the time it's printed on the bottom of the modem/router you got from ATT. Once you enter in the security code you should have full access to the web.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old October 31st, 2009, 07:49 PM     #3 (permalink)
He who is Nude.....
Nude_Lewd_Man's Avatar
Hi, I haven't done much with Macs before - especially with regards to WLAN setup...
However, I'm presuming that the message about getting a "self assigned" IP address would be the same sort of thing as a 169.X.Y.Z address in Windohs, which is flagged as with a "limited or no connectivity" bubble...
As such, it means that it can't communicate with the DHCP server (which I'm guessing is going to be your 'router') and therefore creates a 'default' IP address...
As I'm on my BlackBerry, I can't try throwing any Google-fu at a certain internet search engine that has six letters, and as I've only really dealt with M$ OSs connecting with a WLAN, I'm a little stuck....although, as your getting a 'connected' message it may not be an issue with the wi-fi security as such...........
Personally, as I've got a better knowledge with M$, I would bring a Windohs machine into the WLAN environment to see what is happening... Having said that, I'm thinking that it could be sonething like the wireless is being segregated from the LAN, and that could be the reason that the wireless isn't getting DHCP - but you could, theoretically, test that by setting the machine with the issue to use a static/manual IP address.....
Let us know how you get on - or if you have any further info.......
Whenever someone says "You can't miss it" I invariably do...
Nude_Lewd_Man is online now   Reply With Quote
Old November 5th, 2009, 01:20 PM     #4 (permalink)
You may want to double check the security. In windows i can put in a WEP PW even if its wrong my comp acts like its connecting then tells me limited or no connectivity. It does this even though the wireless says its connected but doesnt give acess because of an incorrect WEP.
bobreaze is offline   Reply With Quote
Old November 11th, 2009, 07:27 AM     #5 (permalink)
if you are using window and your page is not able to load try to reconfigure your ip address ,try to use default ip if this is not supportive ,enter the ip address,subnet and gateway to configure.sometimes mac is not support the wireless connectivity but windows sometimes never give large bug and solve easily.try to use some network montioring or diagnotic tool to solve your problems.
Judd is offline   Reply With Quote
Cox High Speed internet vs Verizon DSL cmartin23561 General Tech Discussion 23 August 15th, 2005 07:59 PM
Verizon DSL vs COX high speed internet cmartin23561 Networking and Internet 0 August 3rd, 2005 08:29 PM
comcast high speed internet-can't download ANYTHING-what's wrong? sbishops General Tech Discussion 6 December 21st, 2003 11:54 AM
high speed internet in ann arbor WingWizard Networking and Internet 4 July 7th, 2003 04:44 PM
Looking for the cheapest Silicon Valley high speed internet bebeangel General Tech Discussion 1 December 29th, 2002 11:41 AM
Is It Just Me? (2848)
Obama the Muslim (12)
Print spooler problem (10)
Display shows 3x5 inch in middle of s.. (1)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (32)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
