June 27th, 2011, 04:33 AM #1Junior Member
- Jun 2011
- 19
Laptop Does not connect to Wireless
I use windows XP. I recently had to have a new router installed. Old one seems to have died or summit. The standalone computer which has been set up with a password connects easily and works. Another standalone in another room asked for my password- connected and works as well.
My laptop which previously worked very well with the old router , identifies that there s a network, but just fails to connect even after entering the correct password. Any help advice and suggestions most welcome.
Oscar
ramjaminn1@hotmail.com
June 27th, 2011, 06:42 AM #2
What wireless network card do you have? What router do you have? Are you using the windows xp wireless manger or the network card manager to connect to the wireless network?
June 27th, 2011, 07:02 AM #3Junior Member
- Jun 2011
- 19
The Router is a TP - Link. I have no idea what wireless card is being used. It is a Toshiba laptop. The problem seems to be identifying the network key. I enter the exact key that I have set up on my standalone but it does not seem to recognise the key. No error message or anyhing- it justs asks for the network key and confirmation again and again after I try to connect.
I believe my network is set up using Windows.
By the way going on other posts in this forum I have uninstalled the network connection on the laptop and tried again- no luck- the same thing happens.
Oscar
June 30th, 2011, 05:20 PM #4
Are there options in the router or network card software to select mixed mode encryption? You may have to experiment with getting the right type of encryption settings to match that of what the network card is capable of.
IE will not connect to wireless
By Deistic1 in forum Technical SupportReplies: 1Last Post: September 29th, 2009, 05:53 PM -
Using a second wireless router to connect to connect up an XBox
By james789 in forum Networking and InternetReplies: 1Last Post: April 27th, 2008, 03:34 PM -
laptop can't connect to wireless Internet from standby/hibernate
By mikeR123 in forum Networking and InternetReplies: 4Last Post: January 10th, 2007, 02:07 PM -
Connect to two wireless networks at once?
By byunews in forum Technical SupportReplies: 1Last Post: April 1st, 2005, 07:17 PM -
Trying to get laptop to connect to wireless router???
By CraigK in forum Networking and InternetReplies: 7Last Post: June 7th, 2004, 12:00 AM
It's probably highly rated because of the level of violence. The story is decent.
Thread About Anime
