August 16th, 2011, 06:22 PM #1
Wireless and Shared Connection Question
Why hello there TechIMO community!
I have recently purchased a new computer, however it had no wireless adapter, so I headed over to walmart and got a USB adapter. The connection is fair, but I was before this, sharing my laptops connection with my new desktop.
My question is if I use the new wireless adapter I got from walmart and the shared connection coming through my computer(wired), would it be faster or would it be the same?
If it won't increase speeds, please explain to me why, as I am one who likes to have things explained in extraneous detail.
Thanks for the help in advance.Acer 7720zMicrosoft Windows XP(SP3)2GB RAM1.44Ghz Intel Dual Core Processor DvdR Drive 160gb HDD 500gb Seagate HDD(External)
Intel GMA 955 Integrated Sound
August 16th, 2011, 06:31 PM #2
So let me get this straight you connection now is:
Laptop wired then shared to your desktop wirelessly via the laptops wireless card and a usb card on the desktop
and you want to go
Desktop wired then shared out from your usb to the laptops wireless
and you somehow think you are going to gain speed??
August 16th, 2011, 06:33 PM #3
I'm a little confused. Do you have a wireless router?
If you're talking about just using the internet, wired or wireless makes no difference -- you pretty much can't max out a wireless connection with any internet we have available up here (Packerland is kinda sketchy anyway).
If you're talking about between two computers, wired will always be faster.
August 16th, 2011, 06:34 PM #4
RicheemX, laying down the sarcasm!
August 16th, 2011, 06:35 PM #5
Well heck it just doesn't make sense
At least not the way they explained it it doesn't. You are using the same hardware and same connection you aren't going to see any difference.
Now if you throw a router in there and connect through that you might because it balances the load. As you explain it it sounds like you are using ICS?? If that would be the case then you are sharing a single connection. The first device gets bandwidth priority in some cases slowing the second.Last edited by RicheemxX; August 16th, 2011 at 06:54 PM.
August 16th, 2011, 06:43 PM #6
Im lost too
August 17th, 2011, 02:39 PM #7
Let me try again
My laptop, connects to the internet wirelessly.
My desktop has no internal wireless card.
I bought a wireless adapter for my desktop like this Linksys Ultra RangePlus Dual-Band Wireless-N USB Network Adapter WUSB600N Network adapter - Hi-Speed USB
If I used my laptop and shared it's wireless connection from the router with my desktop through an ethernet cord, AND was getting a signal from the adapter also attached to my desktop, would it be faster?
If you are still confused, I will create a diagram.Acer 7720zMicrosoft Windows XP(SP3)2GB RAM1.44Ghz Intel Dual Core Processor DvdR Drive 160gb HDD 500gb Seagate HDD(External)
August 17th, 2011, 03:44 PM #8Ok I think I've gotcha now. If I read this right you want to effectively bridge two connections. One directly from the router wirelessly and one bridge via ICS from the laptop.If I used my laptop and shared it's wireless connection from the router with my desktop through an ethernet cord, AND was getting a signal from the adapter also attached to my desktop, would it be faster?
First off I'd get ride of any notion that running anything through ICS is going to give you a boost. Second bridging connection on the same network doesn't do much at all. If you could connect to two different ISPs then yeah but not the way you are talking.
If you are already running a router with a wireless connection to your desktop then you should be getting the best speeds possible.
Perhaps you could better explain what you mean by "The connection is fair"?
You are limited to the speed your ISP is giving you. Is the connection on the desktop slower than the laptop?
August 17th, 2011, 03:50 PM #9
No not slower, it's just fair. My computers internet is fairly average(approximetly 200kb/s)
I just wanted to see what would happen if I did such and such. Just a way to get a better grasp on the world of computing
. Thanks for the information!
Question about the Wireless connection!
By drummerboy in forum Networking and InternetReplies: 2Last Post: January 11th, 2010, 09:31 AM -
Shared connection
By xvpjebqvx in forum Networking and InternetReplies: 4Last Post: June 27th, 2008, 06:03 AM -
Wireless Connection Question (s)
By Jarrod in forum Networking and InternetReplies: 4Last Post: August 30th, 2006, 04:15 PM -
laptop/wireless connection question!?
By optinox in forum Networking and InternetReplies: 1Last Post: December 8th, 2005, 01:37 PM -
Wired and wireless connection question.
By RAR in forum Networking and InternetReplies: 2Last Post: January 11th, 2005, 09:27 AM
Valve cover gasket is shot and it leaks out the back. It's going to get fixed. Someday.
