April 27th, 2012, 09:53 AM #1Junior Member
- Apr 2012
- 7
3COM Switch 3300MM - 3C16988A - Does this have a web interface
hi
our company has bought 10 old switches to use at our site. I have configured them by Hyperterminal and once installed , you can get through to the network and internet.
We have 2 of the 3300XM - 3C16985B switches and I can get to these via the ip number through a browser. I have looked for documentation on the MM switches and on some it states that you can see the switch through a web browser and on others you cannot.
Can someone please tell me if the MM series can be accessed through a web interface?
Also I have left the SLIP at 192.168.101.1 - Subnet 255.255.255.0 - should this be changed
Thanks in advance
April 27th, 2012, 09:58 AM #2
Do you mean 3com not Cisco?
3C16988A-US 3Com SuperStack 3 Switch 3300
Were these switches reset to factory settings before you put these switches on your network?
Here is the manual
http://h20000.www2.hp.com/bizsupport...Fc02582893.pdf
April 27th, 2012, 10:02 AM #3Junior Member
- Apr 2012
- 7
Oh Sorry - 3com
April 27th, 2012, 10:04 AM #4Junior Member
- Apr 2012
- 7
Looked at your link and thats the one
April 27th, 2012, 10:06 AM #5
Yes there is a web interface, check out the manual. Go to into the section of the CLI to see if the web interface is enabled
April 27th, 2012, 10:07 AM #6Junior Member
- Apr 2012
- 7
Yes they were reset and then I put in our ips, etc
April 27th, 2012, 10:13 AM #7Junior Member
- Apr 2012
- 7
Sorry to be so stupid - looking at the CLI - what am I looking for ?
April 28th, 2012, 09:22 AM #8
When you try to access the web browser of the switch what message/error do you get?
Can you ping the switch management address from your computer?
Are you using http or https to connect?
What browser are you using to try to connect to the switch?
Is telnet enabled on the switch so you can remotely log in? Can you log in through telnet successfully?
April 30th, 2012, 06:37 AM #9Junior Member
- Apr 2012
- 7
Hi
Sorry have been off line since you posted questions. Thanks for the updates, here are the answers:
1)Cannot establish a connect to the webpage
2) No I cannot ping when connected - although when we put it on the network, anyone attached to it can get to all servers, etc
3)http: to connect
4)IE 9
5)I have not used Telnet - I have used Hyperterminal and when connected via serial, I get through. I have sinced used putty and connect ok via the serial connection
Setup
IP: 172.20.0.56
Subnet 255.255.248.0
thanks
April 30th, 2012, 09:00 AM #10
What software version is running on the switch?
Can you give us a crude diagram of your network? Are you using vlans? Do you have any kind of access list to dent certain traffic to certain segments? You being able to not ping the management interface tells me something is blocking the traffic to the switch being a misconfiguration of vlan settings or something dropping it like an ACL
April 30th, 2012, 09:33 AM #11Junior Member
- Apr 2012
- 7
Software is 2.66
Have 1 VLAN - 172.20.0.1
No access lists
Have checked one of the 3300XM'S that we have on line and I have set the same settings but still can't get on
how to display mac-port table in 3com switch?
By yaniv in forum Networking and InternetReplies: 3Last Post: June 5th, 2012, 07:56 AM -
Level One Router To 3com Switch Connection
By Cosmas in forum Networking and InternetReplies: 6Last Post: July 9th, 2007, 01:37 PM -
3Com OfficeConnect vs HP ProCurve switch
By ArcticFox in forum Networking and InternetReplies: 9Last Post: October 10th, 2004, 12:41 AM
16-hour days can be brutal.
