Wireless networking
Currently Active Users: 1158
Discussions: 204,487, Posts: 2,419,111, Members: 249,908
Old July 26th, 2002, 10:53 AM   Digg it!   #1 (permalink)
WingWizard's Avatar
Wireless networking
We're putting up a wireless network in our house soon, and I know the current standard is WiFi (802.11b), but I was just wondering what the difference was between 802.11b and the new 802.11a ; will an 802.11b card work with an 802.11a router? thanks
WingWizard is offline   Reply With Quote
Old July 26th, 2002, 10:57 AM     #2 (permalink)
addicted
DVNT1's Avatar
kwebb will probably give you a better answer, but my 2cents... the 802.11a std. allows for faster transfer rates but shorter wireless range and more expensive. 802.11b cards will not commonly work with 802.11a devices. There may be some wireless APs that can have dual wireless cards and thus can support both stds; not common for home models though.
DVNT1 is offline   Reply With Quote
Old July 28th, 2002, 09:35 PM     #3 (permalink)
802.11a has a faster POTENTIAL data rate.
That said, keep in mind that 802.11a devices are:
More expensive.
More sensitive to "interference" (microwave, cell phones, cordless phones, remote controls, etc).
Easier to block with interior walls (sometimes an 802.11a device can't reach into the next room unless you have line-of-sight).
More succeptible to meteorological interference. Did you know we are entering a phase of increased sunspot activity?
With all the above in mind, your mileage wil LIKELY vary. In fact, I have been hearing that the 802.11b devices are more dependable "in the wild". And the transfer speed difference is negligible to a human. Unless you have a constant, multi-gig transfer going on...
UncaDanno is offline   Reply With Quote
Old July 29th, 2002, 10:05 AM     #4 (permalink)
Sorry but no. Much less susceptible to interference from Microwaves (2.4-2.5 Ghz) cell phones et al.......
True enough the shorter wavelengths make penetration of obstacles a little more difficult but that is overblown. 802.11a AP's are pushed with more power, especially at the higher frequency ranges of the AP. .11a is faster under any circumstance. That of course is assuming you are able to get an association from client to AP at the same range as a .11b AP. The weakest .11a link is still 6 mb. Mileage varies but enough of the .11a won't make it to the next room BS. Having said that, different Mfg's breed different levels of quality. If your .11a AP won't make it to the next room, take it back and go buy a Proxim Symphony 802.11a AP. The technology itself and frequency do not inhibit multi-room pentration of the carrier.
Transfer speed is not neglible "to a human" whatever that means either unless your only using this for internet sharing. If file transfers are part of the equation then it is extremely noticeable.
Wingwizard, as DVNT1 mentioned, 802.11b client cards will not associate to an 802.11b AP. The exception would be an AP that has multiple PCMCIA slots and allows two radios in it to broadcast, one at 2.4 and the other at 5 Ghz.
kwebb is offline   Reply With Quote
Is It Just Me? (1525)
CBO: Obama's health care plan cuts .. (57)
would this build be enough for WOW? (14)
The Local Weather Thread (701)
Recent Problem (9)
Suggestions? (6)
Want a new power supply for my Dell.. (35)
Motherboard the culprit? (5)
Can't Rename Files (11)
[ F@H Chat] 03/07/10 New Month New.. (88)
Need some suggestions on building a.. (21)
I need help Guess what happened to .. (5)
Windows XP Pro Error log (6)
My PC shutsdown after 30 minutes of.. (5)
How to Remove DRM from Protected Vide.. (0)
Audio skips when I play a cd or dvd o.. (0)
Computer For Sale*Media Center*Motoro.. (0)
Replacement hard drive for Dell 600M (17)
Recent Problem (9)
E:\Pictures is not accessible. the d.. (2)
Want a new power supply for my Dell. (35)
Selling Xbox Live 1 month codes!!! [$.. (1)
[ F@H Chat] 03/07/10 New Month New T.. (88)
Suggestions? (6)
Drive 0 not found: Serial ATA, Sata-0 (7)
3D Pinball for Windows High Score (122)
mac noob in need of help please (0)
Hard drive full = slower computer? Is.. (4)
Processor speeds? (19)
Clean up safe to delete? (4)
Where to buy 3Rsystem Iceage 120 Boss.. (3)
Need some suggestions on building a g.. (21)
2.6.12, Linux kernel (3)
I need help Guess what happened to my.. (5)
Can 2 cards run off 1 pcie 16 slot (2)
Microsoft removes hardware virtualiza.. (0)
