I suspect your routing information was not set up correctly & after you dialed with kppp all your traffic was routed out the NIC instead of the modem; I have seen it happen several times in the past.
Anyway glad you got it sorted.
Regards
eddy
I dreamt that a large eagle circled the room three times and then got into bed with me and took all the blankets.
