Results 1 to 4 of 4
    The Nebish Jurist Brangwen's Avatar
    "Now?"
    3,228
    Settings keep changing! How come?
    Fellow Members:
    This is an Email (Outlook Express) problem, but as there's a router involved I'm posting in this forum.
    For a reason that I cannot figure out, my Outlook Express settings change by themselves!
    I set my POP server -> = incoming.verizon.net
    I set my SMTP -> = outgoing.verizon.net
    This problem is only on the Primary computer cabled to a Linksys 4-Port Router. Verizon is my DSL ISP, and has been for a year. Verizon notified its customers to change our POP and SMTP settings as shown above instead of:
    SMTP: = smtp.verizon.net
    POP server: = vzexxxxx
    for security issues.
    Since doing this, I've discovered 2X in 2 days that I've been receiving email, but others have not been receiving mine. I discovered this when a couple of people I had notified by email not to come from out of town showed up at my door! I thought they were simply being rude by disregarding me. Turns out they never received my email!
    The email I send appears in my "Sent" folder, not my "Outbox" folder as one would expect a failed email to end up.
    The Second computer cabled through the Router has none of these problems.
    Also, after a day or so - and this has been happening for months - the above values all turn to digits, e.g. 12.0.0.16 instead of the original words I had typed in ---> anyone know why?
    Thx.
    Brangwen
    Edit: I'm using Win2KPro with all the Security Patches on my Primary box, Win98se on the Secondary computer.
    "Now?"
    3,228
    Also . . .
    When I change my Outlook Express Server settings (POP & SMTP), the email works ... Once I reboot, the settings change and do not work, and must be reset to work again!
    Any ideas???"
    Brangwen
    ASUS A7N8X-E Deluxe, Athlon XP 3200+, 1.5 GB Samsung [400 MHz] DDR, Matrox Parhelia 128 Graphics, Dual LG FLATRON Displays, WinXP Pro SP3
    zen
    zen is offline
    Ultimate Member zen's Avatar
    Jan 2002
    Pennsylvania
    3,656
    Are you using Norton?
    "Now?"
    3,228
    zen:
    No ... I use [color=dark-blue]eAnthology[/color] AV software.
    I finally resolved my problem by switching to Netscape. Actually, kind of a nice change. I think I had some damaged computer code, and likely could have fixed it by reloading Outlook.
    Brangwen
