Join TechIMO for Free!
Thread Tools
Currently Active Users: 2220
Discussions: 186,591, Posts: 2,226,869, Members: 230,214
Old December 18th, 2002, 10:46 PM   Digg it!   #1 (permalink)
Send a message via AIM to zskillz
dang... i think this is some sort of basic network problem that I need some help with
so on our network at school, the DHCP server assigns addy's that have the same first two IP sections but varies the second two sections so IP's are something like
1st.2nd.3rd.4th categories
xxx.xxx.aaa.whatever
or
xxx.xxx.bbb.whatever
So the problem for me is that if i'm using a windows network, I can't see the machines with a different 3rd category then me in network neighborhood. I can ping them, so I know that they are there, but I cannot see them.
I'm assuming that it's because the windows networking only looks in the range of the 4th category when populating that list...
anyway, can someone help me out here? Oh, and I'm sorry, that this is so far from the correct technical jargon, but I don't know the words for what I'm trying to describe.
-Z
zskillz is offline   Reply With Quote
FREE instant scan
Old December 18th, 2002, 10:53 PM     #2 (permalink)
mickwish
Posts: n/a
Called subnets, I believe.
Windows network only looks at same subnets specifically AFAIK. If ya wanna look at different subnets ya gotta be more specific.
What OS are you using?
When you map drives I believe you can specify different subnets - but ya gotta know what drives are there to map, I think.
I only deal with my home LAN, which is same subnet. So someone help out poor zskillz here, please??
Cheers
Mick
Old December 18th, 2002, 11:06 PM     #3 (permalink)
yes they are subnets, however you can see beyond different subnets if the routers in the middle allow you to.
There's a number of factors involved...
If you have subnets of
192.168.1.x
192.168.2.x .. they can still be in the same "subnet" if the subnet mask allows for it.
subnet mask of 255.255.255.255 only allows for 192.168.1.1 to 192.168.1.255 if I remember right (I hate tcp/ip lol)
NOW if you have a subnet mask of say
255.255.254.0 you can go from 192.168.1.1 to 192.168.2.255 ...
These aren't exact numbers as there is some math involved.
some info
http://www.practicallynetworked.com/...samesubnet.htm
http://www.subnetonline.com/subnet/step4.html
btw, each "section" is called an octet as it represents an 8bit number
vass0922 is online now   Reply With Quote
Old December 18th, 2002, 11:36 PM     #4 (permalink)
addicted
DVNT1's Avatar
Sounds like they have the LAN segmented to improve performance.
Out of curiosity, what subnet mask are they using?
To make computers in other subnets show up in NN (Network Neighborhood), I believe you would have to have a WINs server (but I'm not 100% sure). I simply do not use NN nor MNP (My Network Places). If I need to access the machine I simply type \\computername\share in the RUN field.
DVNT1 is offline   Reply With Quote
Old December 19th, 2002, 12:55 AM     #5 (permalink)
umm... i'm not sure
it's xxx.xxx.83.xxx and xxx.xxx.84.xxx
and when I have it set to "auto detect IP" I get a subnet mask of 255.255.255.0
As far as I can tell it's divided by floor of the building (this is the nanotechnology education building at my school). I have an office on 2 different floors, and my group wants to be able to see what I have shared.... I couldn't care less... I'd do it more like DVNT1's way, but they don't know syntax, and don't want to.
OK, just read one of those links... it seems as if the problem would be taken care of if I changed the sublnet mask to 255.255.0.0
Is that correct?
-Z
Old December 19th, 2002, 01:03 AM     #6 (permalink)
no, you can't just change your subnet mask.
your dhcp server tells you what your subnet mask is, and the router in between expects it.. or you're not getting through
TMK of course
Old December 19th, 2002, 01:12 AM     #7 (permalink)
well crap....
based on the reading that I have just been doing... we are a Class B network that uses a Class C subnet mask. Unfortunately, i don't think that our network admin knew that there would be at least of few compters on different floors that were in the same group (and thus should have been in the same subnet)
so the question I now have then is... Do i need to just talk to the admin and see if he can change the DHCP server so that hte subnet mask is 255.255.0.0?
It's pretty important, because the machines that we have attached to the lasers are downstairs and we need to be able to check up on them from above.
-Z
Old December 19th, 2002, 08:29 AM     #8 (permalink)
addicted
DVNT1's Avatar
Perhaps you could just make a shortcut on the desktop that points to your shared folder. Then copy or email it to theirs.
Point it to \\zskillzs\shared
Old December 19th, 2002, 10:10 AM     #9 (permalink)
It all depends on how your segmented. If routers are in place to segment the /24 networks then I doubt they will be changing any masks. Perhaps. Using the UNC path as DVNT1 mentions is worth a shot.
kwebb is offline   Reply With Quote
Old December 19th, 2002, 12:18 PM     #10 (permalink)
Well, my boss is the dean of the dept., so he can put his foot down and probably get something done about it. I'll talk to him and some admin guys as well....
DVNT1. That would work fine for me... the problem is that we're trying to clean up the network and all our computers so that they run smoothly and that they all run essentially identically. Since some people use computers on different floors, this would complicate the matter. Since we're dealing with important data, a mistake is quite unwelcome.
just out of curiousity - what would happen if i changed my subnet mask?
-Z
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
heatsink issue (7)
Is It Just Me? (492)
Why Does the MOON Grow Bigger as It.. (11)
New Mobo (16)
1 internet. 1 house. 3 computer. ho.. (10)
Connected to LAN but unable to use .. (5)
heatsink issue (7)
Hard Core Overclock (7)
FS: New Benny Hill Megaset DVD .. (6)
Computer won't start (2)
New Mobo (16)
1 internet. 1 house. 3 computer.. (10)
Request for recovary system ins.. (0)
Folderchat: The Holiday thread (111)
am2 on 939 (4)
Folderchat Weekday thread (411)
