January 28th, 2003, 10:17 PM
| | Registered User
| help!!! my DSL is very slow!
for some reason my DSL has gotten very slow. when i use Kazza or download something using internet explorer from the web, the speed is only about 10 - 20 kb/sec. it used to be around 60-100 kb/sec. i have no idea what is wrong. the browsing has gotten slower too. almost like dial up. can anyone hear help me?
thanx  |
January 28th, 2003, 10:19 PM
| | the *Voice* in your Head
it sounds like your first step of action should be to call the dsl people.
but check out network card setings to make sure you're running at full duplex and not half.
also, please tells us what your os and hardware are. |
January 28th, 2003, 10:36 PM
ok for some reason it won't let me post so i had to go dreat a new account. anyway,
tahnx for ur quick reply. yes i did contact the dsl company and they made me do a bunch of setting and stuff and it still didn't help. i spent about an hour on the phone. Quote: |
| what do u mean? how do i do it?
and im running win xp pro and sys specs are:
p4 1.7
asus p4te mobo
256 mb rdram
D-link DFE-530 tx ethernet card
40 gb harddrive
ati radeon 7000 64mb
thanx |
January 28th, 2003, 10:39 PM
mine was doing that too for about a week then it back to normal but if you mite think its something with your settings tryhttp://www.pcpitstop.com/default.asp
Run the PC Pitstop Internet Speed AutoFix http://www.pcpitstop.com/internet/default.asp |
January 28th, 2003, 11:17 PM
right-click on 'network neighborhood', right-click on the local area connection and select properties. click on the configure button and then click on the advanced tab. you'll see a link speed & duplex setting. |
January 29th, 2003, 10:17 AM
ok it was on auto negotiation and as soon as i changed the setting to "100basetx full duplex" i got disconnected from the internet. |
January 29th, 2003, 12:00 PM
try 10mbps full-duplex instead... |
January 29th, 2003, 12:13 PM
tried that too. same thing happened. |
January 29th, 2003, 09:52 PM
common guys i need some more help. |
January 29th, 2003, 10:18 PM
It may just be that your ISP is trying to recoup from the W32/SQLSlam-A or
SQLSlammer worm that has embedded itself in many an unprotected windows network. My ISP had issues with this over the w/e and it has since cleared up, however I have read that a few ISP's are still experiencing issues. If this is the case, than all you need is a little patience and time. (It probably wouldn't hurt to call your ISP and reference this worm issue either)
hifi
Lian-Li PC1100 Plus
DFI-NF4 Ultra-D
A64 3700+ San Diego @2750 1.5Vcore
XFX GeForce 7800GTX
2X WD 74GB Raptors
OCZ PC-4000 VX Gold 4X512
