Results 1 to 10 of 10
    Mar 2003
    Surrey, UK
    112
    Question Need help setting up Linksys Wireless 54G router with Cable
    I just bought a 4 port linksys Wireless 54G router and I can't seem to configure it properly...
    Has anyone set this up as a router??
    If so please advise!
    Cheers!!
    ><> FishSponge <><
    Registered Linux User: 313906
    FOR ALL YOUR UNIX QUESTIONS & DISCUSSIONS, VISIT: http://unixforum.co.uk
    Tech IMO Bug Finder pickel's Avatar
    Sep 1999
    Jackson,MS
    12,930
    Wink look here
    http://www.linksys.com/support/support.asp
    http://www.youtube.com/watch?v=iE9TN...eature=related
    The Nation which forgets it's defenders will itself be forgotten
    You cannot make peace with dictators. You have to destroy them–wipe them out!
    NOVA
    33,778
    46
    what part are you having problems with? getting internet? setting up the wireless? setting up the hardwire? seeing computers on the network.
    Basically its as simple as plugging in the router, then the modem, then connect the computers. What wireless network cards are you using?
    Did you try Google yet? Siliconjunkie's Avatar
    Feb 2003
    Buckhannon, WV
    3,468
    I have one and it was just that simple.. plug it in, turn it on.
    Can you provide more information about the nature of the problem please?
    Mar 2003
    Surrey, UK
    112
    thanks for your help people... this was actually a problem for a work colleague of mine, and he has sorted it out now, thanks to the FAQ on the Linksys site.
    ><> FishSponge <><
    Member Aniki Kubayashi's Avatar
    Dec 2002
    Chicago, IL
    98
    I have the same one, I just plugged it in and it's done. Check the firmware and make sure you have the latest firmware on the router. They had a recent firmware on this unit released early this month. Call linksys if re-flashing the firmware did not help.
    Jun 2003
    I just bought one the other day and had some trouble as well. Use the setup disk that comes with it. That is what actually made it work for me. If you have more than one wireless computer, make sure to run it on those as well.
    The on screen instructions are pretty simple and you should be up and running in no time.
    Feb 2007
    3
    Hey,
    can anyone help me?
    I just bought a Linksys Wireless G Router and Im having a problem setting it up. Im not sure if you need this, but in order to get the internet working on it, do you need to have a modem to do so? Because I just plugged in the Router to my Computer with the plug it came with.
    Thanks!
    -Lexi
    NOVA
    33,778
    46
    Please start a new thread, there is no reason to post in a thread that is almost 4 years old.
    Feb 2007
    3
    oh, i hadnt noticed. my bad.
