Odd Mozilla problem
Currently Active Users: 1093
Discussions: 204,486, Posts: 2,419,107, Members: 249,906
Old April 15th, 2003, 08:43 AM   Digg it!   #1 (permalink)
Fossil
Theophylact's Avatar
Odd Mozilla problem
I've moved [my wife] Marcia's Mozilla files (mail, address book, bookmarks) to another machine (K7S5A, Duron 950, 256 MB DDR RAM, clean install of Win XP Home, Mozilla 1.3) and got everything working (after some initial difficulties).
But there's a continuing odd problem. Before I transferred the files, she was having trouble deleting mail. She could highlight an item (or a group of items) and delete it; but if she then tried to delete another item or group, it just wouldn't do it. She had to exit Mozilla entirely and restart it before she could delete the next item. That's a real annoyance, and the same problem is true on the new installation.
The problem must lie in one or more of the files I transferred. Is it the "prefs.js" file, and if so, how can I edit it to cure this? Or should I just create a new user profile, saving the mail, address and bookmark files? Or what?
Theophylact is offline   Reply With Quote
Old April 15th, 2003, 11:42 AM     #2 (permalink)
skuz's Avatar
Are these big mails ?
I noticed Mozilla takes its time to delete mails, especially those with a file attached. You can actually see the delete progress bar in the lower right.
I wonder why.
skuz is offline   Reply With Quote
Old April 15th, 2003, 01:11 PM     #3 (permalink)
Fossil
No, some of them are quite small, and text-only. Furthermore, they can't be dragged to another folder without restarting Mozilla, either, after you've performed the operation once.
Old April 15th, 2003, 01:21 PM     #4 (permalink)
rpertusio's Avatar
Send a message via AIM to rpertusio
Is she using IMAP mail or POP?
If using IMAP, deleting a message will delete it from the server. If the server fails to respond (or is very slow), then Mozilla may be 'waiting' for the server, thus preventing any further action.
There are other possibilities... but if you try any, DO back up her profile, in case something goes wrong!!
Mozilla profiles should be stored in:
C:\Documents and Settings\[username]\Application Data\Mozilla\
To play it safe, you might as well back up that entire Mozilla folder. If anything goes wrong, just revert back to your backup.
Her profile could be corrupt. If you know how to, you can re-create her profile.
You could have also stumbled upon a bug in Mozilla. If you are courageous enough, you could upgrade to a newer version of Mozilla (alpha or beta 1.4) and see if the problem goes away.
You might also try checking the "prefs.js" file. Open it in notepad, and check that all the paths match up. You should see some references to her mail settings. Ensure that they are not pointing to a location that does not exist.
Lastly, you could simply uninstall Mozilla, and re-install.
- rp
rpertusio is offline   Reply With Quote
Old April 17th, 2003, 08:37 AM     #5 (permalink)
Fossil
It's POP. Her preferences, however, are set not to save mail on the server.
Her prefs.js file, which I edited so it would point to the correct path, seems to have grown from about one-and-a-half printed pages to at least four.
I don't think upgrading is going to do the trick; she and I both use Mozilla 1.3, and I don't have this problem, while she did on two different machines, one with Win98SE, and a newer one with a clean install of WinXP and Mozilla. It's clearly something in the copied-over files. But what?
I can probably get around this all if I create a new profile for her. If I do, though, how do I transfer her address book and mail without screwing things up?
Is It Just Me? (1523)
CBO: Obama's health care plan cuts .. (57)
would this build be enough for WOW? (14)
The Local Weather Thread (701)
Recent Problem (9)
Want a new power supply for my Dell.. (35)
Suggestions? (6)
Motherboard the culprit? (5)
Can't Rename Files (11)
[ F@H Chat] 03/07/10 New Month New.. (88)
Need some suggestions on building a.. (21)
I need help Guess what happened to .. (5)
Windows XP Pro Error log (6)
My PC shutsdown after 30 minutes of.. (5)
How to Remove DRM from Protected Vide.. (0)
Audio skips when I play a cd or dvd o.. (0)
Computer For Sale*Media Center*Motoro.. (0)
Replacement hard drive for Dell 600M (17)
Recent Problem (9)
E:\Pictures is not accessible. the d.. (2)
Want a new power supply for my Dell. (35)
Selling Xbox Live 1 month codes!!! [$.. (1)
[ F@H Chat] 03/07/10 New Month New T.. (88)
Suggestions? (6)
Drive 0 not found: Serial ATA, Sata-0 (7)
3D Pinball for Windows High Score (122)
mac noob in need of help please (0)
Hard drive full = slower computer? Is.. (4)
Processor speeds? (19)
Clean up safe to delete? (4)
Where to buy 3Rsystem Iceage 120 Boss.. (3)
Need some suggestions on building a g.. (21)
2.6.12, Linux kernel (3)
I need help Guess what happened to my.. (5)
Can 2 cards run off 1 pcie 16 slot (2)
Microsoft removes hardware virtualiza.. (0)
