Wireless or wired
Currently Active Users: 2182
Discussions: 200,919, Posts: 2,379,030, Members: 246,286
Old May 30th, 2003, 01:36 AM   Digg it!   #1 (permalink)
Send a message via AIM to naujcdl
Wireless or wired
network? Well, here is the setup: the basement and first floor are ready for computer usage, but i have a wired connection. One d-link router and two compters sharing the connection, i want to find a way to avoid all the cables and stuff around the first floor. Is wireless something better to have when you have computers in different rooms? Or is it better to have it as it is, cables running all around the house???
Thanks, let me know.
naujcdl is offline   Reply With Quote
Old May 30th, 2003, 01:38 AM     #2 (permalink)
Micro Bean's Avatar
Go wireless because if you dont like where you place your computer you can move it anywhere and not go through that costly rewiring junk hehhehe
Micro Bean is offline   Reply With Quote
Old May 31st, 2003, 03:33 AM     #3 (permalink)
wireless is great but sometimes it drops packets when you play heavy duty LAN games...for everything else it rocks.
If the cabling is really ugly and bothering you that much than go wireless otherwise put the wires behind the walls and get some wall plates and patch cables and make it a weekend project to get the cabling as clean you can :>
Fanzoo is offline   Reply With Quote
Old May 31st, 2003, 11:47 PM     #4 (permalink)
thank you, thank you...well, i don't feel like dealing with those cables anymore. I may end up going wireless, but i only have one worry, what is the transfer rate on music and stuff as such. I mean, with cables, it is fast, but with wireless(from what i have read), it seems to be lower. I am more into forums, little kazaa downloading, but big on hotmail messanger. What do you really recommend, and also the taping the cables around just makes it a big headache, unless i start making holes around and make it all neat... What do you suggest??
Thanks.
Old June 2nd, 2003, 08:27 PM     #5 (permalink)
Well if you're transferring files between computers within your LAN, wireless is definitely going to be slower than a wired setup. But for doing things on the internet it makes little different. I can still get my full ADSL download speed with one of my computers that's connected with a wireless NIC. Cause even though your wired NIC can go up to 100Mpbs, most home broadband setups can only go as fast as 10MBps.
NoLimit is offline   Reply With Quote
Old June 4th, 2003, 12:18 AM     #6 (permalink)
pickel's Avatar
Send a message via Skype™ to pickel
I have four on the wire and my laptop wireless and and can't tell any difference surfing the net. Sharing photos my be a little slower wireless.
Confucius Say: Don't be afraid of opposition; Remember : A kite rises against the wind.
pickel is online now   Reply With Quote
Old June 5th, 2003, 12:12 AM     #7 (permalink)
Thanks again...
sounds interesting, but i have another question now, what happens or what is done if i want to host a website(i will, i am getting things together)?
Am i going to be able to do this, i am new and learning the whole networking deal, especially that now i am going to host a website from my house. Please let me know what is your take on this...
Old June 5th, 2003, 06:32 AM     #8 (permalink)
Did you try Google yet?
Siliconjunkie's Avatar
Send a message via AIM to Siliconjunkie
You will still be able to host if you want. Acts just like wired as far as TCP/IP is concerned.
Siliconjunkie is offline   Reply With Quote
Is It Just Me? (2839)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Virus Doctor Popup? (1)
Foreign voltage (8)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
