Thread: DSL HELP
August 9th, 2003, 12:02 AM #1Junior Member
- Aug 2003
- Location
- florida
- 4
DSL HELP
Having trouble with my DSL. I keep getting "p2p can't start server message" it pops up every 20 seconds or so. I can reboot and it will stop for a while but start up again. Hope someone can help. Thanks
Cash Nelson
August 9th, 2003, 12:16 AM #2
Is this popping up in a p2p program... or is it a windows message.
Welcome to TechIMO
The more info you tell us the more we can try to help. What OS are you running? Some Basic System Specs (NIC too)? What DSL ISP do you have?
August 9th, 2003, 12:18 AM #3
Welcome to TechIMO!
Urban is back.
And yes that is how you spell my name. I am living proof that 2+2=5
dontforget/rgdesb
August 9th, 2003, 12:28 AM #4Junior Member
- Aug 2003
- Location
- florida
- 4
I am running Windows XP Professional. As far as the the network card I am not sure. I know it's some generic card, it may even say Network Card on the box. Another thing is I am using Sprint Fastconnect which uses Earthlink.net for the ISP. Well hope this helps.
August 9th, 2003, 12:31 AM #5Junior Member
- Aug 2003
- Location
- florida
- 4
I lied it the NIC is a Davicom 9102.
August 9th, 2003, 12:33 AM #6Junior Member
- Aug 2003
- Location
- florida
- 4
Thanks Urban
August 9th, 2003, 02:48 PM #7
Is this when you're using a Peer-2-Peer program (like Kazaa) or just normal Internet usage?
Sean
August 9th, 2003, 04:36 PM #8Ultimate Member
- Apr 2003
- 2,083
might need to run a spyware program, could be a bug
Athlon 64 3400+ (22-28*C)
ECS 755-A2 1.1B Bios
40GB & 80GB Internal HDD
160GB External HDD
Corsair 2GB PC3200 RAM
ATI AIW Radeon 9600 128MB 8X
August 16th, 2003, 02:06 PM #9Junior Member
- Aug 2003
- 3
Same problem
Hi everyone, this is my first post.
I have the same problem with the pop up window saying "p2p Networking" "Can't start server".
I'm sure it's related witk Kazaa, since the problem began after I installed this program recently.
Thanks for any help!
August 16th, 2003, 03:31 PM #10
When this happens can you still use Kazaa?
August 16th, 2003, 05:54 PM #11Junior Member
- Aug 2003
- 3
I couldn't tell. Kazaa is running in the background when I start the computer, but the message keeps popping up even after I close Kazaa.
I think I have gone through this sequence:
start computer
pop up alert comes in
close Kazaa
pop up stays for a while and then stop
start Kazaa, everything works fine (including downloads)
August 20th, 2003, 07:44 AM #12Junior Member
- Aug 2003
- 8
i have the same problem...have you had any luck with figuring it out yet?
August 20th, 2003, 08:17 AM #13
Hi,
Did anyone tried using a virus scan?
One time I was helping a person with his computer and it keep of saying that message. So I ran the virus scan and it repair/deleted some infected files, and the message hasn't popped up since.....
also... Welcome to TechIMO!
August 20th, 2003, 08:19 AM #14Junior Member
- Aug 2003
- 8
Well - I have run a scan from Symantec - is there anywhere else I can run one from? I also have Zone Alarm installed which does not seem to be helping....
August 20th, 2003, 08:23 AM #15
Did you try running the AdAware Program from Download.com? Its a free program that will scan your computer for Spyware and that could be the problem.... Go to: www.download.com and search AdAware.... Thanks
August 20th, 2003, 08:25 AM #16Junior Member
- Aug 2003
- 8
thanks - i will give it a go!
August 21st, 2003, 08:20 PM #17Junior Member
- Aug 2003
- 3
Sorry that I was out for a couple of days... (problems with the router, fixed).
Kazaa remains as a chapter of "Unsolved Mysteries". Now, I noticed that the problem seems to happen while switching between users in WinXP . When I login to my account and stay there, everything is fine.
I'm gonna try the program that imac9556 suggest...
Regards!
August 22nd, 2003, 07:49 AM #18Junior Member
- Aug 2003
- 8
Yeah - my problem occurs because of having 2 users. I have completely uninstalled Kazaa and will possibly download Winmx or Kazaa-lite. I keep trying to download the recommended software - but it is not having it!!
It's all that clandestine umbrella drill that makes him so good at it.
