XP - Wireless Network problem
Currently Active Users: 2178
Discussions: 200,919, Posts: 2,379,027, Members: 246,286
Old November 17th, 2003, 04:34 PM   Digg it!   #1 (permalink)
I bought a USR Wireless Turbo Access Point & Router and two USR pci cards to make a network with two pc.
Was not easy but now I have the two PCI work with the Access Point (both receive the IPs from there).
With one PC I can ping the router but not the other PC.
With the other one I can’t ping the router neither the other PC but I can Ping the 127.0.0.1 and the IP of the PC himself (see attach).
Some times in the two PCs I can see both in the “Workgroup computers” but I never can open the remote PC they say there are no permissions to use Network; but I think that this is not the problem because in one PC I never could ping the router and the other PC.
There are no firewalls
There are the same Workgroup and users in both PCs.
The both PCs as the some config but one is XP Home (the one that can Ping the router)
I can_t put the local net working.
I need help, please
Thank you, and sorry about my English
Jose
zegonc is offline   Reply With Quote
Old November 17th, 2003, 07:11 PM     #2 (permalink)
Father V2.0
washe's Avatar
Send a message via MSN to washe
Few questions?
Are you using DHCP on the router? (Thats the one that assings the ip addresses).
Type on prompt ipconfig /all, post the results of both computers.
someone is more skilled than you!
http://s7.bitefight.org/c.php?uid=23753
washe is offline   Reply With Quote
Old November 18th, 2003, 05:33 AM     #3 (permalink)
Yes I'm using the DHCP from the router.
What is funny is that the PC connects with the router with very good signal strength but I can’t ping it and neither the other PC.
Ideas are welcome
Old November 18th, 2003, 03:49 PM     #4 (permalink)
Father V2.0
washe's Avatar
can you post the ipconfig /all information of the adapter, there we can see if effectively the adapter is talking to the DHCP.
Old November 18th, 2003, 05:06 PM     #5 (permalink)
As you can see the PC can talk with DHCP but nothing happens more
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\zegonc>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : zegoncPC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
PPP adapter SAPO Dial-Up PPP Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 81.193.10.185
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 81.193.10.185
DNS Servers . . . . . . . . . . . : 194.65.5.2
194.65.3.21
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . : zegoncHome
Description . . . . . . . . . . . : U.S. Robotics 802.11g Wireless Turbo
Adapter
Physical Address. . . . . . . . . : 00-C0-49-CB-CE-DD
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.123.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.123.254
DHCP Server . . . . . . . . . . . : 192.168.123.254
DNS Servers . . . . . . . . . . . : 192.168.123.254
Lease Obtained. . . . . . . . . . : terça-feira, 18 de Novembro de 2003
21:01:24
Lease Expires . . . . . . . . . . : terça-feira, 25 de Novembro de 2003
21:01:24
Old November 18th, 2003, 05:53 PM     #6 (permalink)
Father V2.0
washe's Avatar
nope..... its taking an automatic address...
Adapter 1 IP address: 81.193.10.185
Adapter 1 Subnet Mask : 255.255.255.255
Adapter 2 IP address: 192.168.123.100
Adapter 2 Subnet Mask : 255.255.255.0
If you see both adapters have different addresses so looks like the DHCP of the router is not working your network at it should, here you have two different networks... thats why you cant ping each other and one pc doenst has internet access.
To be able to see them and access the computers on the network the both adapters need to have same ip address range and same subnet mask by example...
Adapter 1 Ip Address: 81.193.10.185
Adapter 2 Ip Address: 81.193.10.186
Subnet mask for both adapters 255.255.255.0
Plus the DNS and Gateway information needs to be the same... this for internet access.
One more thing do you have a seen on pc 1 i see a Dial up adapter not the ethernet card?
Do you have broadband? is this connected to the correct port in the router?
Old November 18th, 2003, 05:55 PM     #7 (permalink)
Father V2.0
washe's Avatar
Forgot one thing from the very beggining......
Welcome to Techimo!!!
Old November 18th, 2003, 06:03 PM     #8 (permalink)
This IP is Wan, is from my internet usb modem(Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
IP Address. . . . . . . . . . . . : 81.193.10.185)
This is from my wireless adapter:
Adapter
...and come from DHCP of the router
the other PC as 192.168.123.101 also form the DHCP
After what happen wrong I don't know, help me please
Old November 18th, 2003, 06:18 PM     #9 (permalink)
I send three e-mails to the USRobotics support but they don’t answer me; in Portugal they don’t answer to the phone , this is like a joke.
So, don’t buy USRobotics products because, as you see they don’t have support.
Old November 18th, 2003, 08:21 PM     #10 (permalink)
Father V2.0
washe's Avatar
Can you please post your modem model and Router model to take a look on their website..
- Can the usb model be connected to a port on the router (usually wan port).
Dont worry we will try to help you out with this small problem.
Is It Just Me? (2839)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Browsers wont load websites (1)
Foreign voltage (8)
Virus Doctor Popup? (0)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
