Results 1 to 10 of 10
    Ultimate Member Vagabond's Avatar
    1,757
    Question Wireless Lan issue
    Hey all
    I have a laptop running win2pro and I can not get the wireless card to work.. I have tried uninstalling and reinstall even went and re-installed the op sys...
    I get this error..
    Domain Setting Error
    Can not open any adapter
    Doamin setting was cancelled
    when i go to install the drivers for the WLAN card...
    Under the device manager the WLAN card has an ! mark on it and under properties it says Code 10 This device can not start... Under Device usage it is enabled.
    any thoughts
    txs
    Senior Member imac9556's Avatar
    Oct 2002
    Leawood, KS
    828
    um.. this might sounds weird. but did you check your BIOS settings that your PC Card is enabled? I think its called CardBus or something like it...
    Because I used to have a PC lappy and when I wanted to use that wireless LAN card for the 1st time, it wouldn't detect it. I checked my BIOS settings and the CardBus was disabled. When i enabled it, it worked perfectly.
    NOVA
    33,788
    46
    please list the model of the card.
    1,757
    Hey imac txs for the suggestion but that was not it...
    It says its a
    IEEE 802.11 11 Mbps Wireless LAN PCI Card from Gemtek and RealTek drivers
    that is all i could find (may not be looking in the right spot)...
    txs
    You know dog spelled backwards is god.....
    coincidence ..... i think not.
    Jan 2004
    currently the USA
    24
    Hey,
    So this is a WAP card, and this is for a laptop, ok. Is this PCMCIA? If so, many versions of windows prior to XP have had compat. problems. If you are going to solve this, you need to install yupdated drivers, and check the BIOS which you did. If all else fails man, i wouldnt bail on this idea. Since it is a hardware issue, you might also want to check to see if it is in the HCL of Windows. That might also be a problem, could solve much of your question.
    Good Luck ey :-D
    Cheers,
    Dan
    1,757
    txs ill look
    it is not aPCMCIA card it is internal...
    its a Sager laptop
    Ultimate Member AzKidd69's Avatar
    Queen Creek, AZ
    1,480
    have tou tried contacting Sager about it?? They can be really good about getting things up and running for you. I am sure theyhave seen the issue before... and I am currently looking into that error message win2k gave you. not sure wat that will net but it's a new one to me.
    Never argue with a computer, without a hammer.
    Never program and drink beer at the same time.
    Never trust a programmer who carries a screwdriver.
    Queen Creek, AZ
    1,480
    after some digging I found this....
    http://notebookforums.com/archive/index.php/t-1806
    both people who had the same error as you had bad cards.....
    but there are a few other things to try first too....
    1,757
    txs send message to Sager waiting for call back
    1,757
    Update:
    I am sending my wireless adapter back to Sager they are going to replace it...
    hopefully this will fix all my problems.. (and I do mean all LOL)
