Thread: the IE problems continue
January 27th, 2004, 10:51 AM #1
From the beginning..... I built myself a low end gamer with a K7S5A pro, 2400+, 512 Crucial 2100, 120 GB Western Digital and Powercolor 9600XT. I loaded XP and then the mobo drivers from the CD. In my stupid desire to play CoD (which I got for Christmas) I hooked up to my router checked IE and loaded my game. Next time I launched IE my homepage was some bs search engine. I have reset several times only to have it come back to the search engine. It was at this point that I realized that like a person suffering from HUMA (head up my arse) I never loaded Norton. I loaded Norton, d/l adaware, trojan hacker and spybot and installed. It appears after deleting/quarantining some files I still have some problems. I don't get all the pics to load on the techimo home page (as well as others) nor do links in posts work. I am no longer getting any hits from spyware/antivirus proggies so I am in a quandry. If I run my mouse over links in posts, my cursor stays in the "hand" form and I don't get the page loading bar at the bottom of the window. Eventually the system will time out and bring me back to the post page. I can click on buttons link forums or news ( it does this on all sites) I tired to "remove" IE through control panel but that only removes the icon. So I "need to do some of that pilot @$&* Mav". Would someone like to be my RIO?
January 27th, 2004, 11:06 AM #2Not Really a Member
- Oct 2001
- 27,856
Have you tried simply reinstalling IE?
Redownload it, and go through install process
During the install process there is also a "Repair" option if I"m not mistaken.Helicopters don't fly; they vibrate so much and make so much noise that the earth rejects them.
January 27th, 2004, 11:14 AM #3
You may find some help here.
IE hijack
Scroll down
Bill*****
The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
January 28th, 2004, 12:57 AM #4
I didn't get to try much with it tonight, but I did redownload IE6. When it goes to install it gets to 83% and quits. Says something about the "win logo.....not being compatible with XP" I also tried to just delete the IE folder I already had and it wouldn't let me do it. Said that IE is running....I didn't have it open. I created another account on the machine and had the same problem. I am not that strong with registry editing so that is out if I have to manually find the problem there. Could it be some dll file in the windows directory? Oh and I never saw an option to "repair" when trying to reinstall IE. Maybe I should just give up and reinstall XP from the get go....just hate to lose my saved games on my game partition. Any ideas? Thanks
January 28th, 2004, 01:07 AM #5
Maybe try a "Repair" install of WinXP... boot from the WinXP disk, skip the first "Repair" option (it goes to the Recovery Console, which is not what we want in this case) and use the second "Repair" option it gives you (have your CD key ready). That should fix IE and you won't have to re-install everything else or lose your saved games. The only thing that you may have to re-install is any Symantec/Norton stuff... usually gets fubar'd on my system everytime I do a Repair install.
January 29th, 2004, 01:50 AM #6
Ok, I d/l several free reg fixing programs. They found several errors and eventually all were repaired. Still got the problem of not being able to click on links. Cursor never changes to hourglass, just stays the hand. I did a repair of XP Pro, made sure all was ok with Norton so I hooked my cable connection back up. Well my home page was reset to space-search again and I still cannot click on links in posts. Suggestions? this is just ticking me off to the highest level of tickivity!
January 29th, 2004, 02:13 AM #7
just ran hijack this and all "seems" to be ok at the moment....do I dare shut the system off and see what happens? why heck ya I gotta do that........btw didn't fix anything HT found...back in a sec
January 29th, 2004, 02:19 AM #8
yeehawwww all is working just hope like heck it does tomorrow....shoot I guess I have to get up early and turn it on to see.....bottom line is I don't know what fixed it.....as an avionics tech that just baffles me....all I know now is NTFWI
January 29th, 2004, 05:14 AM #9
Windows is like that, heh. Congrats
NTFWI?
January 29th, 2004, 08:11 AM #10
Not To "Fiddle" With It......it's still good this morning too so I guess something I did changed something somewhere somehow someway.
January 30th, 2004, 09:04 AM #11Member
- Jan 2004
- 115
spyware guard will prevent hijacking your home page or installing dialers.
http://www.wilderssecurity.net/spywareguard.html
I boogered it up. Don’t know where to go in the machine or how to readjust.. So hoping someone can kind of give me directions on how to “unscrew it” My machine specs. AMD Athlon processor...
Lately I.E. has become a dog. ...
