Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
    geforce4 ti4400 problems
    i have a 128mb geforce4 ti4400 that a bough a couple years back and for the past year or so, its been freezing whenever i start a game.
    when the problem first started it used to go at least an hour before it would freeze, now it doenst last 2 minutes. its only in 3D games. when playing games with no graphics (risk) it works fine. ive tried downloading new drivers but nothing fixes it. im so confused on whats happening.
    the interesting thing is ive found a small forum online (i forget the site) that had 5 or 6 ppl with the same exact same problem with the same card but from different companies (mine was from leadtek) they never found a solution
    the computer game would just freeze and the screen would not have any motion. a split second of the audio would rerun over and over sounding like a screech. the only thing i can do is hold the power down. ive done this so much ive screwed up a hard drive and had to buy a new one. im desparate here. any help?
    im running
    amd athlon 2000+
    512mb ddr ram
    leadtek geforce4 ti4400 128mb
    160gb hard drive
    please please please help me
    Ultimate Member proffit's Avatar
    Jul 2004
    brisbane
    2,427
    i have no idea how to fix this. but if it is causeing so many problem run out and buy a new cheap graphics card. it is better then haveing to go and buy a new hard drive and looseing all your data. some things like this will do well it is only 70 http://www.newegg.com/app/ViewProduc...170-024&depa=0
    Jul 2004
    brisbane
    2,427
    also forgotto mention welcome to techimo.
    thanks for welcoming me. feels great to be here.
    wow a 5200 for 70? is there something i should know about this? it seems insanely cheap... i never heard of albatron
    btw. if im gonna buy that card do i just turn off this computer and plop out my current one, buy the new one and put it in? is it that simple?
    San Diego, CA
    6,398
    Yeah, what you should know is that your TI4400 is WAY more powerfull than that 5200.
    FLAC Trooper ArcticFox's Avatar
    Jan 2003
    A theater near you
    5,425
    How much do you have to spend on a new card?
    My Ti bit the dust a little while back also.
    Full Time WoW Addict nwo75200's Avatar
    Jan 2004
    Cleveland, OH
    8,571
    Arrow
    Quote Originally Posted by stingystooge
    Albatron is a pretty good brand, they're big in Europe A regular 5200 for 70 bucks... that's expensive IMO!
    yea, anyways, how much are you looking to spend, and what preformance do yo expect to get... do you want something that will match the ti4400 preformance or do you want something better?
    Jul 2004
    brisbane
    2,427
    yeah i thought that the 4400 was better but i figured it would be cheaper to get a new graphics and not a new hdd. any way how much do you have to spend or want to spend. i think your card is on its last legs. tells us what you want and we will help you out
    Jan 2004
    Cleveland, OH
    8,571
    Lightbulb
    This should be way better as far as preformance/price goes compared to the 5200 mentioned above
    http://www.newegg.com/app/viewproduc...134-108&DEPA=0
    cooler looks nice too
    well to be completely honest i only have whatever my ti4400 sells for on ebay. which is around 50 or 60.
    but what i REALLy want to do is to fix my current ti4400. i never knew my card was better than a 5200. i just thought 5200 was better since it came out later. what would be a card equivalent of its performance?
    does anyone have a way to fix this problem?
    Jan 2004
    Cleveland, OH
    8,571
    Arrow
    Something like 5700NU should come very close the preformance of a ti4400
    San Diego, CA
    6,398
    Quote Originally Posted by nwo75200
    I have that very same card in one of my boxes. Although its not quite as fast as my Ti4400 in another box, it doesn't do too bad either. For the price its great, especially since its got the 128bit memory interface as well as VIVO. The cooler is actually pretty weak, its just a small hsf with a big blue plastic piece that you see there covering it. It does have 3 blinking RGB LED's though.
    Ultimate Member shawshank62's Avatar
    Oct 2002
    Philadelphia
    4,791
    Which drivers are you downloading? The best drivers for the ti-line of cards are the 43.xx through 45.xx Also, what is the ambient temperature of your system? maybe the card is overheating.
    I have been running my ti4200 at speeds close to a ti4600 for 2 years now, so i would say don't spend the money on a new card yet.
  15. #15
    if i already have another driver, if i install a older driver will i be fine?
    also does direct x have anything to do with my problems?
  16. #16
    Fur ballin Sixpac_XP's Avatar
    Victoria, BC
    4,371
    What operating system are you running? Have you ever reinstalled the system from scratch.. eg reinstall the O/S and drivers and programs?
  17. #17
    Perfetc Member VHockey86's Avatar
    Jan 2003
    Maryland Suburbia
    4,334
    Goto the control panel --> add/remove programs and uninstall the "nvidia display driver" Reboot and then install the other drivers.
    Installing 1 driver over another generally works ok, but since you're already having problems you mide as well eliminate as many variables as possible when attempting fixes.
  18. #18
    im running windows xp professional.
  19. #19
    Jan 2004
    Cleveland, OH
    8,571
    either get a new video card, or reinstall windows, there's nothing else you could try ...IMO (well you already tried the drivers and etc.)
  20. #20
    sigh... man that sucks.
    p.s. what does IMO mean?
  1. DOOM3
    By fufiter9246 in forum General Gaming Discussion
    Last Post: August 19th, 2004, 02:21 AM
  2. overclock ti4400 to 4600 speeds
    By PastranA in forum PC Hardware
    Last Post: July 27th, 2004, 12:22 PM
  3. G4 ti4800?
    By Hopper in forum PC Hardware
    Last Post: January 13th, 2003, 09:29 PM
  4. suggestions
    By Vagabond in forum PC Hardware
    Last Post: November 18th, 2002, 08:48 PM
  5. graphic cards
    By super gerbil in forum PC Hardware
    Last Post: November 17th, 2002, 05:52 PM
