Results 1 to 12 of 12
    Dec 2004
    SKYPE ME
    21
    Post Max IDE on 939 MoBo
    Which 939 Motherboard (as supplied retail) provides maximum number of IDE channels available for use ? I thought I saw a 4 channel (8 IDE devices) but do not recall ID. Some have max 3 IDE channels, with a Promise controller w/ RAID avail for 1 IDE channel or for SATA. But lacks RAID for IDE and SATA, only one your choice for RAID setup. Been looking @ reviews, so much stuff, so little real info.
    Desire 8+ IDE devices, plus SATA RAID 0, plus 2 SATA drives.
    Any recommendations or experiences??
    Ultimate Member HeadBand's Avatar
    Dec 2003
    3,988
    if you cant find one you could always get a pci controller
    http://www.newegg.com/app/ViewProduc...104-214&depa=1
    Hey who turned sigs on?
    Dec 2004
    SKYPE ME
    21
    Cool to HB, Koutech IO-PIR133
    TY but am looking for MoBo w/ the max IDE as supplied retail.
    The Koutech PCI controllers you recommend handles 4 IDE devices, and/or supports RAID, so I could hook up 4 DVD burners and burn to all 4 simultaneuosly?
    Any problems with spacing PCI cards to allow ribbon cables install (air flow, etc)?
    Wow, with a PCI card like that coudl I potentially add two more IDE drives without sacrificing two of my existing IDE drives?
    Pardon my ignorance, I did not know such things existed and if so I am very interested ...
    Senior Member bfcx's Avatar
    Oct 2002
    557
    Yes, you could get as many of the PCI cards as you could fit in your computer and put as many IDE drives as you want.
    Ultimate Member SpaceSquad's Avatar
    Nov 2004
    Ottawa, Ontario
    2,742
    how much loss of transfer speed, ect?
    Nov 2004
    Ottawa, Ontario
    2,742
    if any?
    Onii-san Bizkitkid2001's Avatar
    Sep 2002
    San Antonio
    11,606
    no loss in speed if accessing just one drive. But I do notice lag when I am trying to access more than one IDE drive on the controller card at the same time.
    Ultimate Member [Neo770]'s Avatar
    Gold Coast,Australia
    2,478
    Well the PCI bus is more or less 133 Megabyted per second. And it would take a pretty good SCSI array to fill that all the way, so the loss of transfer rate compared to a MB IDE controller would be nothing.
    Dec 2004
    SKYPE ME
    21
    Exclamation Koutech PCI controllers on SL-K8TPro
    I got an PSA-150 (SATA RAID in slot 1) and PIR-133 [(2 Channel IDE w/ RAID option) in slot 2, but not working yet]
    Have the SATA RAID w/ Win XP loaded now, but had some problems.
    Did not work at first as listed in user manual . After days of experimentation I fiqured it out, boots real fast. I think quicker than on board IDE, SATA or PDC 579 !
    Am running 4 different RAID 0 setups now !
    2 WD360GD raptor (different controllers), Max160,
    The Koutech PCI IDE controller you recommended can handle 4 IDE devices, and/or supports RAID, so I could hook up 4 DVD burners and burn to all 4 simultaneuosly?
    Not many problems with spacing PCI cards to allow ribbon cables install (air flow, etc).
    can't raid cd drives lol. on the other hand with a program like nero you can use asynchronous (spelling?) burning to burn to all of them at once!
    Quote Originally Posted by [Neo770]
    the loss of speed has to do more with the pci bus being slow and the card being slow to access two drives at teh same time rather than the 133mbps speed of the ata interface
    /edit (which is the hardware and which is the interface...ide and ata..which is which?? AAHH!!!! lol)
  1. AMD cpu and Motherboard question?
    By optinox in forum PC Hardware
    Last Post: October 15th, 2004, 08:11 PM
  2. help with gaming desktop!
    By SlAve101 in forum General Tech Discussion
    Last Post: September 16th, 2004, 12:05 AM
  3. AMD 64 754 or 939 pin?
    By micfau1091 in forum PC Hardware
    Last Post: September 1st, 2004, 10:10 PM
  4. geforce fx5700/256mb vs fx5900se/128mb
    By doc675k in forum PC Hardware
    Last Post: July 29th, 2004, 05:08 PM
