Results 1 to 4 of 4
    Member rwinegar's Avatar
    Mar 2003
    93
    SVGA/VGA Pin configuration
    I recently purchhased a Samsung 204T 20.1 inch monitor. The supplied VGA cord was too short to reach to my computer. I needed about two more feet. I ordered a high quality SVGA cable on line. When it arrived I discovered that pin number 9 is missing. The original monitor cable had all 15 pins. Is it safe to use this new cable on my monitor? I found out that many VGA/SVGA cables do not have a number 9 pin. But I don't know when the number 9 pin is required.
    Is my new monitor safe with this new cable?
    Thanks.
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,562
    Should be fine. If it don't work, it won't work.
    Aug 2003
    Madison, WI
    15,220
    Yea, it is fine, most cables don't have a #9 pin.
    Mar 2003
    93
    Thanks for your help.
  1. 9-pin to 15- pin VGA question.
    By bill1971 in forum PC Hardware
    Last Post: December 16th, 2012, 12:53 PM
  2. two 3-pin case fans on 1 3-pin mobo power slot?
    By _Switch_ in forum PC Hardware
    Last Post: May 28th, 2005, 02:20 PM
  3. Power pin configuration
    By geosca in forum PC Hardware
    Last Post: August 7th, 2003, 03:55 AM
  4. 232 pin & 184 pin pc1066 RDram?
    By massacres in forum General Tech Discussion
    Last Post: May 15th, 2003, 10:30 PM
  5. 72 pin & 168 pin memory, which to upgrade?
    By desmocat in forum PC Hardware
    Last Post: October 18th, 2002, 11:29 AM
