Results 1 to 12 of 12
    Member mista_haqeem's Avatar
    Jul 2006
    KL, Malaysia
    189
    Unhappy i need help bad!
    i've already overclock my processor from 2.8ghz to 3.2ghz...
    it runs just nice...
    but the main problem is the temperature...
    sometimes it reach at 55 celcius...
    i've already put a lot of thermal compound on it...
    can i make the processor cooler?
    my specs:-
    P4 775 2.8ghz@3.2ghz
    ASUS P5V800 motherboard
    512mb apacer value ram
    80gb SATA II HD
    Gecube 9600xt AGP 8X
    Cooler Master Real Power 450watt PSU
    Cooler Master Hyper 48 cpu cooler
    3 casing fans
    Healdsburg, CA
    13,880
    yea, if you want to go cooler, a water cooling setup is in your future.
    Senior Member MrPurple's Avatar
    Jan 2002
    Staten Island, NY
    730
    That might be one of your problems, too much thermal compound.
    Too much and you are going to actually inversely affect heat conduction between the CPU and the heat sink.
    You could try a different heatsink. There are plenty out there now with 92-120 MM cooling fans.
    Also alot is dependent on your case air flow and the ambient tempertaure.
    If the ambient is fine, then i would look into the case airflow as well as getting rid of some of that thermal greese, a thin layer is all that is enough, more will hurt you rather then help you.
    -=Marcin=-
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,363
    4
    Well he is saying it "reaches" 55*c so i'm assuming it's his load temps. If so, 55* isn't bad for a late gen p4.
    4K PC: Intel i7 4790k @ 4.7ghz / 16gb DDR3 2400 / Sapphire R9 290X / Win10 Pro
    HTPC: Intel Pentium G3258 @ 4.2ghz / 8gb DDR3 1333 / Evga 750ti / Win8.1 Home
    Laptop: Lenovo G50-45 / AMD A8-6410 / 8gb DDR3 1866 / Win10 Home
    Ultimate Member Jarhed7276's Avatar
    Apr 2003
    Texas
    2,230
    Quote Originally Posted by mista_haqeem
    Perhaps that is a problem. You do not want to put a lot of thermal paste on the CPU. You want just a thin even layer.
    If that temp is when it is under a load that is a good temp. If that is an idle temp it's not too bad. Mine idles around 50-52 C during the summer and mine is not overclocked.
    I'm not familiar with your CPU cooler so I can't say whether it is a good one or not. Maybe someone else can answer that for you. I use a Thermalright XP-120. It is a good cooler but I am not impressed with cost to performance ratio. If I were building a system now I would use the Thermalright XP-90.
    So if someone suggests a new cooler you might consider the XP-90.
    "Retreat, hell! We just got here."
    - Capt Lloyd Williams at the Battle of Belleau Wood
    Jul 2006
    KL, Malaysia
    189
    i'm looking for a cpu cooler that i can control the fan...
    Jul 2006
    KL, Malaysia
    189
    water cooling...
    argh....
    i like one of those...
    but it's too expensive...
    maybe later...
    hehe...
    Jul 2004
    921
    Can you please run prime 95 and tell us the temps it reaches , I dont consider my cpu stable till i can run Prime for 24+hours with out a error .
    As stated before if 55 is you load temp that isnt the end of the world as it is summer time , Somthing cheep that you can do is make a duct from the side of your case that maybe has a extra fan that is directed right on your Cpu HSF
    Intel 4670k @ 4.7ghz 1.35v (75 Deg load with Linx water cooled ) /Asus Z87-Plus / Gskill 2x4gig Pc-2133 11-11-11-30-1T
    Antec 650w / Ati 6950 2gig /Kingston 120gig SSD
    Jul 2006
    KL, Malaysia
    189
    Quote Originally Posted by ||Console||
    where can i get prime 95?
    Jul 2004
    921
    Google is your friend
    分かりますか。 carl33p's Avatar
    Feb 2006
    Houston, TX
    7,183
    9
    http://files.extremeoverclocking.com/file.php?f=103
    ^^ Just in case Google isnt your friend
    Jul 2006
    KL, Malaysia
    189
    Sometimes google is my friend....
    Ahaha...
    Thanx carl33p for the link...
    ehehe...
  1. Bad Bad Newegg
    By Slayertime in forum PC Hardware
    Last Post: August 27th, 2004, 03:12 AM
  2. ndis.vxd ....... bad ..... bad load ?
    By PartsMan2 in forum Applications and Operating Systems
    Last Post: November 23rd, 2003, 06:00 PM
  3. Not bad, Newt, not bad.
    By M_Six in forum IMO Community
    Last Post: August 3rd, 2003, 02:03 AM
  4. need help bad
    By Greasy Burger in forum General Tech Discussion
    Last Post: January 28th, 2003, 08:24 AM
  5. Help, I need help..really bad
    By couch potato in forum Networking and Internet
    Last Post: January 11th, 2003, 01:30 AM
