Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
    Ultimate Member Coolzer's Avatar
    Mar 2005
    Australia
    1,112
    Old computer Problem
    Hi..
    I'm fixing a computer for a friend. He requested that i buy a 5 port USB PCI Card, and a CD burner. The CD Burner Installed fine but when i insert the USB card, the computer refuses to boot (monitor doesn't turn on)
    I know the mobo is a DFI K6BV3+ and i think the cpu is a K6 500mhz....
    (I'm not real good with old PC's...considering i was about 10 years old when this computer was brought out.....)
    I have tried
    • Connecting it in every PCI slot
    • Flashed the BIOS
    • Tried card in another computer, it works, (no problem with card)
    Ultimate Member Milwaukee's Avatar
    Apr 2006
    Detroit, MI
    1,273
    Well sound your friend's power supply watts is underpower. I guess your will be 250 or less watts.
    sorry for my bad grammar!
    Mar 2005
    Australia
    1,112
    Na don't think thats the problem.....
    A 300watt PSU..
    He is only running a single 4GB HDD, CPU, MOBO, VGA card, CD Burner.....3
    Thanks for the post though
    Apr 2006
    Detroit, MI
    1,273
    well that strange but what spiec on video card? I think it video card pull lot watts from psu which cause less watts for another electirc in computer.
    Try remove cd burner and put oringally cd driver and try with usb card if it work mean PSU is low.
    Mar 2005
    Australia
    1,112
    Na the Video card is just a standard crappy VGA S3 card (4mb of graphics memory, that kind of crappy )
    Apr 2006
    Detroit, MI
    1,273
    well I think it better build new computer for now.
    Mar 2005
    Australia
    1,112
    Building a new computer isn't an option, as thois computer is only going to be used for Word processing and music....
    Aug 2003
    Madison, WI
    15,220
    Where would you get the idea that his power supply is bad? If adding a 5w pci card makes it unbootable it would be completely unstable all the time without it anyways.
    I really don't know what is going on though, I would need to see it happening and watch everything to figure it out. Just don't have enough details.
    Mar 2005
    Australia
    1,112
    Yeah, sorry about that....This is all i know. I was thinking that it might have something to do with the mobo IRQ list
    "I know the mobo is a DFI K6BV3+ and i think the cpu is a K6 500mhz...."
    That along with a 4GB HDD and CD Burner.....
    分かりますか。 carl33p's Avatar
    Feb 2006
    Houston, TX
    7,183
    9
    Think the mobo may be so outdated, that it doesnt recognize the USB PCI card?? (Dont know if its possible)
    Do you have any other current-date PCI cards that you could test in the mobo?
    Aug 2003
    Madison, WI
    15,220
    Could be, I am pretty sure it has to do with some bad option in the BIOS, but I don't know what a lot of those options do.
    Mar 2005
    Australia
    1,112
    I check, but i don't think so.....
    It's really strange...I have no idea of whats going on....
    Ultimate Member uethello's Avatar
    Charlotte, NC
    1,785
    According to http://www.motherboard.cz/mb/dfi/K6BV3+66.htm this has onboard USB, if that is correct, have you tried disabling the onboard USB via the BIOS?
  15. #15
    Jul 2006
    27
    Question usb problem
    hi like one of the other guys posting a reply without knowing more its hard to say what is causeing the prob but if it is a k6 setup maybe it cannot handle a modern usb card as i believe they used usb 1.1 the card will be usb 2 which i know is backward compatable but not if the system wont find it try the bios if all is ok then try safe mode
  16. #16
    Smile. It's easy. :) paul9's Avatar
    Aug 2003
    Gateshead U.K.
    14,174
    Is there a BIOS option in there for the PCI type to use? If there is, try PCI 1.1 or the highest version available, instead of PCI 1.
  17. #17
    Mar 2005
    Australia
    1,112
    Quote Originally Posted by wera View Post
    What brand usb card is it?
    along the lines syba or sabernet?
    The brand is LASER
  18. #18
    Mar 2005
    Australia
    1,112
    I've found a manual for the mobo...
    http://www.dfi.com/download/MANUAL/39220935.PDF
  19. #19
    Augsburg, Germany
    5,584
    First thing to do is scratch that "IRQ conflict" idea. That's an urban myth.
    Also, the board's hardware level of PCI support is a given, and it's at least 2.1. The board's PCIBIOS will also be at least 2.1, but that all doesn't matter zip.
    What exactly is happening? Does the board not fire up at all anymore with the USB card in? Or does it show initial POST screen, and then doesn't proceed to load the operating system?
    Your next attempt should be with a USB card that uses a VIA chip if the current one didn't. Alternatively, your next attempt should be with a USB card that doesn't use a VIA chip if the current one does - the idea being that with the board having a VIA USB controller integrated already, it might fail because it either doesn't handle anything but VIA USB controllers, or because it confuses added VIA USB controllers with the onboard ones.
  20. #20
    Mar 2005
    Australia
    1,112
    The computer turns on, beeps but the monitor doesn't turn on. The computer doesn't continue to boot. (No HDD activity)
    I found an old ASUS adapter and plugged it into the USB connector on the mobo. Now he has USB's. But i would still like to install the PCI card considering that he paid for it.....
  1. Computer Problem?!
    By twendanewhite in forum PC Hardware
    Last Post: January 22nd, 2005, 11:26 AM
  2. Computer Problem
    By magicz69 in forum Technical Support
    Last Post: May 2nd, 2004, 10:38 AM
  3. Computer problem
    By smkeller9 in forum General Tech Discussion
    Last Post: June 25th, 2003, 03:20 PM
  4. Please HELP...computer problem....
    By blood in forum Technical Support
    Last Post: June 22nd, 2003, 08:10 PM
  5. Computer Diagnostic Software (Computer lock up Problem)
    By Fujiiro in forum Applications and Operating Systems
    Last Post: July 29th, 2002, 08:30 AM
