Results 1 to 3 of 3
Thread: rear case fan
    Nov 2008
    New Zealand
    26
    rear case fan
    hey guys
    i bought and installed a 120mm fan at the rear of my case. unfortunately we don't have that great PC stores here, so i had to buy a clear 4 led fan. when screwing it in.. i accidently wore one of the, already crappy, screws. i used a phillips head screwdriver but one of the screws wasn't going in so easily, so i used more force and now the '+' is pretty much a 'o'
    now how big of a problem will this pose if i want to remove the fan lol? it's installed on one of those 'hole punched grills' i know you guys all love
    just passin thru Sweeper's Avatar
    SW, OHIO
    5,849
    Removing the screw shouldn't pose any problem at all. If you can't grab it with anything to turn it then take and grind the head off, off comes the fan. Or drill it out, etc etc.. shouldn't pose a problem at all. They aren't the strongest of screws. Any dremel with a cutting head should take it off with no problem and nearly or no damage to your case.
    Nov 2008
    New Zealand
    26
    i don't have a dremel but im sure dad has some rotary tools in the garage. cheers sweeps
  1. Installing a 120mm Rear Fan problem
    By jimbo_limited in forum PC Hardware
    Last Post: March 23rd, 2005, 06:13 PM
  2. Troubleshooting... Installing 120mm Rear Fan
    Last Post: March 23rd, 2005, 02:55 PM
  3. Intake FAN in REAR of Case ?
    By MegalosSkylaki in forum PC Hardware
    Last Post: April 13th, 2004, 12:19 AM
  4. Rear and Front Fan Question
    By unknown8 in forum General Tech Discussion
    Last Post: July 11th, 2003, 01:21 AM
  5. Case Rear Panel only, Case search, wood mod
    By LaidBackLux in forum PC Hardware
    Last Post: May 18th, 2003, 03:06 PM
