Results 1 to 14 of 14
    Mar 2009
    4
    External Hard Drive not recognized
    I have been trying all day trying to get my external hard drive to be recognized by WinXp but its not working and really beginning to me.
    I check the Device Manager and can see my Maxtor HD there, but when I click My Computer its not there.
    Also when I click the USB controllers in device manager I can't see the USB Mass Storage, whereas I can see all the other USB devices.
    Also when I click the Manage and then Disk Management I can only see my C Drive and no other drives.
    When I plugged the USB cable in it said 'new hardware found' but thats all it says, I can't seem to get it to work. I have tried everything.
    Hope somebody can help me.
    West Haven, Utah
    39,062
    How many drives do you have? I've noticed that sometimes a USB drive won't show up if there are other drives taking up all the letters D: through F:. Can you disconnect other drives to see if it will appear?
    Also, have you tried rebooting the computer? Sometimes that will do the trick.
    Mar 2009
    4
    I have a D drive and normal C Drive. I have restarted my PC and still nothing. Its really annoying me now.
    Mar 2009
    4
    anybody got any tips on how i can get it to work.
    Mar 2009
    4
    I have posted a few images of what is going on:-
    Image 1 -
    Image 2 -
    Image 3 -
    Image 4 -
    Apr 2009
    5
    there must be something wrong between the HDD and PC , another possiblity is the HDD has been dead.
    Call Maxtor for help!!!!
    Apr 2009
    Ok, try the following:
    Right click on My Computer - Properties - Hardware - Device Manager.
    There find Universal Serial Bus Controllers.
    Uninstall USB controllers, USB Composite Device and USB Root Hub.
    Restart system and let it detect the new devices and update drivers for them.
    Then connect your external HDD.
    I recommend you taking backup of your system prior trying this step as it could cause problems. But mainly it resolves the issue.
    Ultimate Member RayH's Avatar
    San Francisco, CA
    2,799
    Try another USB port.
    RayH42450@gmail.com
    Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
    Jan 2010
    Quote Originally Posted by Ramz View Post
    Image 1 -
    Image 2 -
    Image 3 -
    Image 4 -
    Image 1 shows only your primary drive (it is not the external drive)
    I can only assume that the ext drive is dead or one of the components in the interface has gone bad (happens with ext drive enclosures).
    You could try to remove your hard drive from the ext drive and see if you can directly add it to another ext drive enclosure or your machine (sorry if this step is too advanced).
    Jan 2010
    Smile
    sounds like you have done the same thing I did. If you have used computer management you will have formatted the hard drive and also removed all the partitions from it. So what you need to do is download so free software from download.com and then add a new partition to your drive. Once you have done this you will see it appear in my computer.
    Let me know how you get on.
    Regards
    Paul
    Jan 2010
    external hard drive can be seen
    Quote Originally Posted by madnad View Post
    I was having the same problem, this is how I fixed it in XP Pro.
    Start, Right click on My Computer, pick Manage, pick Disk Management, pick the hard drive in the Volume list, right click over it, change drive letter and path, pick a drive letter that is not being used.
    Feb 2010
    15
    Maxtor
    Oct 2011
    WHAT WORKED FOR ME.
    I wasn't able to locate my external hardrive in the disk manager , it was not showing up in "my computer" but it was running and fully functional in the device manager. The. error message i kept getting was that my "external hard drive was not partitioned".So to avoid re formatting or partitioning . I simply connected it to another computer and let it it install as if it were brand new. it partitioned it self and saved all of my data.NOTE .. it may ask if you would like to format .. choose NO!!!! when i was done I connected it back to my original computer and everything was back and running.
    I have experienced a USB external hard drive that is not recognized in "Computer" and is therefore not accessible. The drive does appear normally in Device Manager. Sometimes an external drive which has been in normal use shifts into this situation. In my case the drive appeared to have lost its "designation".
    Other brands of USB external hard drive plugged into the computer are also not recognized, but flash drives are recognized.
    The external hard drive appears normally and works when plugged into other computers.
    To recapture the drive designation on the computer experiencing the problem -
    Go to Contol Panel - Administrative Tools - Computer Management - Storage - Disk Management. In my case the drive appeared, but has no designation letter. I right clicked on the "blank" drive and then
    selected "Make Drive Active" and "Change Drive Letter and Paths". That seems to resolve the problem.
  1. Setting up an External Hard Drive as a Network Drive?
    By Cook_1 in forum General Tech Discussion
    Last Post: January 19th, 2009, 07:20 PM
  2. Replies: 3
    Last Post: May 25th, 2007, 12:17 PM
  3. hard drive not being recognized
    By DeathWish187 in forum PC Hardware
    Last Post: August 29th, 2005, 12:59 PM
  4. hard drive not being recognized?
    By ShuckyD in forum PC Hardware
    Last Post: May 30th, 2005, 11:00 PM
  5. FS: Maxtor External Hard Drive & Pacific Digital External Writer
    By shahani in forum Traders Forum: Buy, Sell, Trade
    Last Post: September 1st, 2003, 06:45 PM
