Results 1 to 2 of 2
    Video Card Upgrade Help
    Hi guys,
    I want to upgrade the video card on my dell dimension 4700 system. The psu on my system is 305w so I know my choices are limited. The card I'm looking at is the ati hd 4670. Although the site state the requirement is 400w, I read all over that many people are able to use it at 300w. I know it also depends on the ammount of hardware that is installed in your pc. My pc is running a pretty light load as of now.
    I basically have: intel p4 530 3.0 ghz, 1.5 gig ram,1 harddrive(5400 rpm at most), 1 cd/dvd rom and 1 dvr-rw/dvd+rw drive.
    From what I can gather the 4700 psu has a dual 12v rails at 18.0amps a piece.
    With the load I have right now is feasible for me to run the hd 4670?
    Healdsburg, CA
    13,792
    Yea, from what I have found, the Dell 305W does have dual 12V rails @ 18A a piece. They are stout little power supplies.
    You may be able to run the HD 4670 on that. If you know of others who have, give it a shot. I figure the worst that could happen is it simply wont boot.
  1. Looking to upgrade my video card...
    By Tommy Kost in forum PC Hardware
    Last Post: April 25th, 2009, 12:33 AM
  2. Video card upgrade
    By Deerhake44 in forum PC Hardware
    Last Post: August 31st, 2008, 08:31 PM
  3. Video Card Upgrade
    By outlaw2001it in forum General Tech Discussion
    Last Post: July 19th, 2008, 09:10 AM
  4. Video Card Upgrade Help
    By mike689x in forum PC Hardware
    Last Post: April 26th, 2006, 08:31 PM
