Results 1 to 10 of 10
    Unhappy USB drive extremely urgent problem, Files cannot be seen but they are there! Help...
    Hi,
    Whenever I plug in the USB into my computer, it could detect it and seems to work alright. My computer detects it and gives the option to play the files.
    However, if I try to browse/explore the device, it's always empty(gives the 'This folder is empty' message). I can't see any of the folders or files on the device and I know they are there because when I rightclick and see the properies, the pie chart shows that some space has been used! It just happened yesterday and please tell me what to do, I have extremely important files on the USB!!!
    I have also tried searching for some files that I had on my USB but it says that it can no longer find them. It says that 'The item 'whatever I searched for'
    that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly. Do you want to delete this shortcut?'
    Please help urgently!
    Mar 2009
    5
    A thought
    Do you by any chance have a U3 drive?
    We have some at work that use hardware encryption and they display the USB drive as two separate drive letters (for instance H and I). If you want to see the files on the drive, you have to select the higher drive letter, in this case "I".
    I'm guessing this may not be your problem, but figured I would at least put it out there.
    35,162
    65
    What does disk management say about the drive?
    What is the make and model of the drive?
    Dec 2008
    9
    try this:
    right click on my computer.
    left click on manage
    left click on disk management
    now look on the right side and see if you see your usb drive if you do then do the followning:
    right click on the drive letter and click on open.
    good luck.
    slatus
    No, I only have one drive letter for the USB drive: E
    GroundZero3
    I took the screen shot of disk management for you:
    MyPicx.com - Disk_management
    If I open the drive(the highlighted one which says: Hassan) it will show me that it it completely empty and if I see the path of it by right-clicking, it shows E drive(which as I explained to slatus, is the original drive in which my usb is inserted)
    As for the model of the USB, I did some additional work for you:
    It's file system states that it is a FAT32 system file. The type is removable disk. I took another screenshot of the properties: MyPicx.com - Properties
    I hope that's enough information... the usb does not has a specific brand name. It's just a regular usb.
    If you need to know what type of usb it is, then here's the place where I bought it:
    New 16GB USB 2.0 Flash Memory Pen Stick 16G Thumb Drive - eBay (item 260389320616 end time Apr-28-09 11:06:34 PDT)
    jerardi
    That still shows that the folder is empty
    I hate to say it but that thing might be a chinese flash drive thats a 1gb with the firmware on it changed to show up as a 16 gb so when you run out of space (1gb) it writes over previous data. though i could be wrong...
    *New* Corsair Obsidian, Core I7 920 stock, Foxconn Bloodrage, 9800GX2 1gb, 6GB DDR3 1600 Patriot "Gamer Series" Swiftech H20-220 w/ Apogee GTZ
    May 2009
    USB Drive
    Had this issue myself and it turned out to be a type of virus or spyware which had set the properties of the file and or folder hidden. Try this. Go to My Computer and select the drive for your USB drive. Next, click the Tools menu, then click Folder Options. Click the View tab, then select/check the box to show hidden files, then click Apply/Ok.
    If this displays the contents of the drive, right-click on each folder stored in it, then click Properties. Uncheck the Hidden option, then click Apply/Ok. If prompted, be sure to select the option to apply the change to all of its files and subfolders.
    be sure to delete any files that were recently added which you did not add and do a virus scan and/or spyware scan on your USB drive and on your computer.
    Hope this Helps!
    Rodietom
    Senior Member evereddie's Avatar
    Feb 2004
    Between NY and Miami
    937
    Also look in yur recycle bin to be sure it wasn't deleted somehow. It would still show up as 'space used' but not accessible.
    Just a thought.
    Another thing is to try and copy the entire drive. Maybe it can copy and then the files will show up.
    Aug 2009
    Miami
    8
    This article doesn't explain how to recover your files, but if your drive is reporting storage incorrectly (i.e. a ghost drive from china), it may help you to bring it to work normally.
    A few things to be aware of before doing so, however:
    • YOUR DATA WILL BE LOST SO BACK IT UP FIRST IF YOU CAN!!!
    • Do not use the utilities included without reading instructions
    • Follow the instructions EXACTLY as they are written
    • DO NOT use or open both programs at once, as it says this can cause permanent damage to either USB or PC!
    Mar 2013
    Thumbs up Use Recovery tool
    Hi
    Hey don't worry, I believe your USB might be infected by virus or got corrupt. There is no need to get tensed for this, Just Chill. You can easily recover your USB files by using the USB File Recovery Software. This software is the perfect solution for your problem. it can perform the USB Stick recovery very easily. So, I think you can try this, as it can support all the popular versions of both Windows and Mac OS. If you want to evaluate it, then you can use the trial version of it and then if you are satisfied you can purchase it. In trial version itself you can view your files and its free. So, just give a try...
    You can find more details about the software here:
    If you need the trial version of the software go here:
    Hope it works...
    Best of Luck
  1. USB hard drive detection problem
    By buscuitboy in forum PC Hardware
    Last Post: September 5th, 2008, 01:12 PM
  2. USB Drive Problem in Vista…ONLY works with NTSF!?
    By lair12 in forum Applications and Operating Systems
    Last Post: August 9th, 2007, 03:26 PM
  3. USB Drive connection causes boot problem
    By The_Diceman in forum Technical Support
    Last Post: February 24th, 2005, 06:41 PM
  4. Temporary files! NEED URGENT HELP!
    By gambler2611 in forum General Tech Discussion
    Last Post: November 26th, 2004, 05:18 AM
