Results 1 to 4 of 4
    May 2009
    4
    Need a Monitor Cable
    I need to buy a new monitor cable to fit into my new graphics card. The cable I need is a DSM-59 to DVI-D, but the only ones I've been able to find are 8 or 9 inches. Do they make ones that are a couple feet long so they can actually reach my monitor to my computor? If so, does anyone know where I could find one?
    AGW Trained Seal tony_j15's Avatar
    Mar 2003
    Joplin, MO
    18,400
    A DSM-59 is a dual display output. Usually, you would hook up a short splitter cable to this and then run two monitors. I think the best solution would be to buy a cheap, short splitter, then plug a DVI cable into it, which you can procure for whatever length you require.
    May 2009
    4
    I'm not really coputer smart lol..is there anyway you could send me a link to a cable splitter I'd need?
    Mar 2003
    Joplin, MO
    18,400
  1. Monitor Cable Help!
    By af240 in forum Technical Support
    Last Post: May 27th, 2009, 02:57 PM
  2. Cable Box to PC Monitor ?
    By MegalosSkylaki in forum PC Hardware
    Last Post: May 26th, 2006, 12:45 AM
  3. Monitor Cable
    By RCN_Moose in forum PC Hardware
    Last Post: July 13th, 2002, 01:01 AM
  4. monitor cable pins
    By cbuddha42 in forum PC Hardware
    Last Post: June 16th, 2002, 08:17 PM
