Results 1 to 11 of 11
    Dark spots on LCD monitor (unlike pressure spots)
    Hello
    I have a laptop that seems to have randomly developed these dark spots around the edges of my screen.
    Its not like when you push on the screen but more like stains. See image. That's the best pic I could get it
    Any thoughts or ideas on how to fix this?
    Thanks!
    South Jersey
    11,363
    Sounds like a problem with the panel itself, as opposed to the backlight for instance. Unless it creates a problem seeing the desktop, it's not worth bothering about.
    Member theGlitch's Avatar
    Jul 2008
    Boston, MA
    185
    If it's an older monitor, it looks like it's on its way out. Perhaps it's a pixel that's dying. In which case, I'd suggest running this dead pixel test. I not too long ago had a monitor die out on me, you can get a real decent LCD for roughly $100.
    bammy pullmyfoot's Avatar
    Aug 2006
    Singapore
    4,383
    Looks like what happened to an old PIII lappy of mine. That one looked a little like it had burn marks on it. Screen still worked though. Your monitor is dying bud.
    Aug 2006
    Singapore
    4,383
    nevermind
    South Jersey
    11,363
    Quote Originally Posted by pullmyfoot View Post
    its a laptop. Replacing the screen will be more like $200-$300 or even $400 if its a big one.
    Not sure where you're shopping, but panels for many popular models can be easily found for under $100. And the replacement is a DIY job.
    Aug 2006
    Singapore
    4,383
    Quote Originally Posted by osprey4 View Post
    really? ok maybe thats because you are in the USA over here its a different story. Forget what I said
    South Jersey
    11,363
    Sorry, my fault for assuming. Yes, outside the US, things can be quite a bit more.
    alrighty.. bad news but it happens =(
    Thanks guys!
    Member brian0555's Avatar
    Mar 2002
    Ohio
    126
    I have the same problem, pic is spot on to what I'm experiencing. Guess there's no real fix, just replace? Seems these spots are multiplying
    Rosetta@Home [XPC ]
    Senior Member evereddie's Avatar
    Feb 2004
    Between NY and Miami
    937
    It has nothing to do with pixels. It's something between the glass layers. Any chance there is a lot of moisture around this computer? Anybody use glass cleaner on it? Put a suction cup on the glass in the area of some spots and very very gently pull on it. Do the spots change?
  1. Blind Spots
    By brandon184 in forum IMO Community
    Last Post: November 5th, 2005, 09:42 AM
  2. spots
    By merv62 in forum Technical Support
    Last Post: March 3rd, 2005, 12:35 AM
  3. About to move up 2 spots!
    By jerrygarcia in forum Distributed Computing
    Last Post: January 23rd, 2005, 04:37 AM
  4. spots on projection screen
    By drledger in forum IMO Community
    Last Post: June 20th, 2003, 03:43 PM
  5. Strange spots
    By Skywalker[TSG] in forum IMO Community
    Last Post: August 20th, 2002, 10:10 AM
