Results 1 to 10 of 10
    Oct 2009
    Indiana
    5
    Exclamation PC: DVI to HDMI Sound Problem!
    Hello, I am running Windows XP Home and I have a GeForce 9400 GT (more specs on it HERE!) hooked up to my Sanyo-HT30744 TV using a DVI to HDMI cable. The TV is supposed to use Component 3 audio input for sound on the HDMI channel when a DVI device is hooked up. When I uninstall the driver to my video card and/or when my PC is booting up and going through BIOS, the HDMI channel displays the notification that you must use the Component 3 input for sound, ext, and works like is should. When the driver is installed and when the boot process gets to the Blue Windows start screen the screen flickers then the TV thinks the HDMI has sound coming through even though it donít.
    Can anyone please help me on this?
    I have messed around with the TV and the NVIDA settings and everything and NOTHING. Is there any pins I can break off the DVI end to make it work or anything?
    USA
    18,875
    is it possible there is NO sound being transmitted from the DVI port on the card to the TV, do you have a pin to connect the audio cable from the Video card to the HDMI audio from your motherboard?
    most Video cards capable of transmitting audio over the DVI out to an HDMI cable or HDMI adapter cable, uses a 2 pin cable from a header on the motherboard or sound card to the video card.
    if this isn't plugged in, if its even available, you won't have any Sound going to the card and through the DVI port.
    Intel Core i5 4690K//CM Hyper 212 Evo/2x Akasa Viper R 140mm//EVGA Z87 Stinger//8GB Avexir DDR3 2133MHz//MSI GTX 760 2GB//XFX XTR 550W//Thermaltake Core V21//Win 8.1 64-bit//Seagate ES.3 1TB 128MB Cache 7200RPM, Seagate Barracuda 1TB 64MB Cache 7200RPM
    Oct 2009
    Indiana
    5
    No it doesn't, I have read in other forums and everything about the SPDIF hook ups, but my video card don't have one. I have noticed though that there are some soder spots on it where the SPDIF inputs are on other video cards. I can take a picture if you would like.
    USA
    18,875
    if there's no SPDIF connection, then there won't be any audio transmitted through the HDMI connection.
    Oct 2009
    Indiana
    5
    I know, but my TV seems to think there is when it is all installed and everything. That is what I'm not getting. I am wondering if it is made or one or not cause I've seen on the internet where other 9400GT cards have them. But I am all out of options on this one.
    Oct 2009
    Indiana
    5
    Here is a pic of the Solder spots I was talking about.
    Light to Counter the Dim MTAtech's Avatar
    Long Island, NY, USA
    12,342
    You aren't getting sound because DVI is a video standard, unlike HDMI that carries both audio and video.
    DVI to HDMI
    Unlike HDMI, DVI usually carries no audio data in its TMDS channel. However, as DVI is for the most part compatible with HDMI (see Compatibility with DVI), it is just as possible to support including audio data by incorporating the audio in the TMDS signal. Because DVI displays typically have no sound capabilities, a DVI to HDMI adapter/cable can then be used to connect the device to an HDMI display. For instance, this feature allows PCs to send audiovisual data to a high definition television. It is increasingly found on modern computer graphics cards (e.g. cards by Nvidia[1] and ATI[2]) and certain motherboards with integrated graphics.
    Thus, if your card is not incorporating the audio in the TMDS signal, you will only get video.
    Conservatives: "If the facts disagree with our opinion, ignore the facts -- or at least misrepresent them."
    Nov 2006
    Portsmouth, UK
    4,162
    Yes and as your card has no SPDIF input im afraid you are SOL. Next time you pick up a video card you should research to see if it has an SPDIF input.
    Unless your feeling skilled with s soldering iron....
    Oct 2009
    Indiana
    5
    I have the cable to run sound to my TV from my PC via Red and White RCA.
    The TV is supposed to use Component 3 audio input for sound on the HDMI channel when a DVI device is hooked up. When I uninstall the driver to my video card and/or when my PC is booting up and going through BIOS, the HDMI channel on my TV displays the notification that you must use the Component 3 input for sound, ext, and works like is should. When the driver is installed and when the boot process gets to the Blue Windows start screen the screen flickers then the message goes away and TV thinks the HDMI has sound coming through even though it donít. What I would like to know is there anyway to make my TV think there that it is just DVI, which it is, like break one of the DVI pins out, tweak the driver or something?
    Senior Member Flying JJ's Avatar
    May 2009
    SE PA near Reading
    666
    What make and model of TV?
    I know on a Mitsibishi you will have to assign the HDMI input (video) to use the Audio 3 in. It will assume that there is an audio signal on the HDMI untill you tell it diffrently. You can pretty much change everything for that matter. This is pretty detailed but there is a great chart in the instruction book.
    If this is a big widescreen, you may just want to upgrade the video card to one with the needed connections. Your picture will also get better. You could also put the cpu audio out to something like a surround sound system.
    Vi per Concordiam
  1. DVI to HDMI sound transfer
    By MRBee30 in forum PC Hardware
    Last Post: May 27th, 2009, 05:22 PM
  2. DVI(PC) to HDMI(TV)
    By ry94080 in forum Technical Support
    Last Post: May 18th, 2009, 11:14 AM
  3. dvi to hdmi or dvi to vga? w/c is better?
    By jprovido in forum PC Hardware
    Last Post: April 15th, 2009, 05:25 PM
  4. DVI to HDMI
    By cyclist110 in forum PC Hardware
    Last Post: May 21st, 2007, 05:37 PM
