Results 1 to 18 of 18
    Ati 6970 XFIRE Problem???
    Hi guys i was on this forum at the start of the year asking what graphics cards to chose i went with the ATi 6970 in XFire, my problem is i don't seem to be getting any proformence increse when Xfire is enable i have change both cards around and tested them by them selfs, both work fine but when Xfire is enabled i get the same FPS or even a little bit less then when i run one card, here is some sceen shots from GPUZ thanks for your help
    Attached Thumbnails Attached Thumbnails -6970-one-gif   -6970-one-2-gif   -6970-two-gif   -6970-two-2-gif
    USA
    18,792
    depending on the games, some don't cope well with crossfire (same with SLI) and may even get less frame rates.
    the GPUz links are showing the cards at idle mode, which is why the clocks are so low.
    Whats your complete hardware system specs?
    Have you tried the latest Catalyst drivers? Shows your using 11.5's, latest is 11.8's.
    Intel Core i5 4690K//CM Hyper 212 Evo/2x Akasa Viper R 140mm//EVGA Z87 Stinger//8GB Avexir DDR3 2133MHz//MSI GTX 760 2GB//XFX XTR 550W//Thermaltake Core V21//Win 8.1 64-bit//Seagate ES.3 1TB 128MB Cache 7200RPM, Seagate Barracuda 1TB 64MB Cache 7200RPM
    Hi there just installed the new drivers but still the same
    PC Specs:
    Power Supply: Thermaltake Tough Power 1500w
    MB: Crosshair IV Extreme
    Ram: Corsair Dominator 8Gb 2000mhz
    CPU: 1100T @ 4.3ghz X 6 Cores
    HDD: WD Raptor X2 (Raid 0)
    GPU: ATI 6970 X2
    Hi could the problem be from my power supply coz I've got 2 types of connections for pci e 1 3volt and 1 4volt I have them in 3volt outlets should they be in the 4volt? Also what do you mean when u say my cards are in idle?
    Nov 2006
    Portsmouth, UK
    4,162
    What games? What screen resolution? What are your average FPS for each game?
    Hi Aaron, All game are in 1920X1080
    Assassins Creed II: 62
    Call of Duty 4 - Modern Warfare: 55
    Dead Space: 35-40
    Dragon Age Origins: 65-70
    Nov 2006
    Portsmouth, UK
    4,162
    Do you have V-sync enabled? I would double check you have it turned off on each game (at least until you find out the problem).
    Forgot to ask for the rest of your system specs...
    GPU-Z should be able to indicate the load on the GPU, you can select it to create a log, run a game then checking the log for the GPU load across both cards.
    Msi afterburner works with AMD cards? Does it have an on-screen display like EVGA precision does so you can monitor FPS and GPU load etc in game....
    Yes V-sync is disabled system spec are up top from earlyer or do you need more?? ill try the gpuz log now
    GPUZ log on both cards
    Attached Files Attached Files
    Nov 2006
    Portsmouth, UK
    4,162
    Forgot about that...
    That's what I get for posting at 4am....
    Are you sure that's both cards? Does it not create separate logs for each.... Either way you are only hitting 30-35% load on that GPU....
    Trying to think of a game that will max out GPUs.... Do you have Crysis 2? If not can you get 3dmark 06, I know the blimp video card test brings both of my GPUs to 99% load.... The score will also show you if you are performing as you should be. Have you tried some older drivers at all?
    No sorry in don't have crysis 2, yeah the first half is one card and the other half is the other card, as for drives i was using 11.5 now using 11.8, ill try 3dmark 06 now
    I have got 3dmark vantage will that do or do need 3dmark 06
    Nov 2006
    Portsmouth, UK
    4,162
    I could never get vantage to work properly.... You can try 11 too...
    down loading now
  15. #15
    Hi i couldn't 11 to finish the tests it kept crashing this score is from vantage all settings set to extreme 18920
  16. #16
    Nov 2006
    Portsmouth, UK
    4,162
    That sounds about right TBH.... GPUs at stock?
  17. #17
    yeah they are
  18. #18
    So there is nothing wrong with my cards? Thanks for all your help once again, one last question can you tell me what the 4volt PCIe outlets are used for on my power supply??
  1. MSI Lightning 6970
    By Dcezy in forum PC Hardware
    Last Post: June 29th, 2011, 03:05 PM
  2. Help Graphics with a 6970
    By Emic in forum PC Hardware
    Last Post: March 3rd, 2011, 04:11 PM
  3. 4870x2 vs 6950 vs 6970
    By RacerX in forum PC Hardware
    Last Post: January 30th, 2011, 11:46 AM
  4. A cure for the Xfire BF2 join game problem !
    By nunyadam in forum General Gaming Discussion
    Last Post: October 8th, 2005, 11:56 PM
  5. aim, gaim, xfire problem
    By butch81385 in forum Applications and Operating Systems
    Last Post: February 14th, 2005, 12:17 AM
