Results 1 to 3 of 3
    SLI 560Ti Aftermarket cooler
    I have an SLI set up with 2 560Ti's. I have been looking around for the best aftermarket cooler.
    I have found the Arctic cooling coolers but I have not seen anyone put them on the 560Ti's.....
    So heres my thing... I want to know what is the "best" VGA coolers for an SLI set up?
    Im tired of it saying 79 for one card and 69 for the other... So I kinda want to bring those down...
    Thanks!
    BTW they are the PNY OC-2 versions
    Member danielwileymail's Avatar
    Apr 2011
    Louisiana
    58
    that top card is gonna run hotter no matter what kind of cooler you slap on them. hot air rises and there's not really anything you can do. those temps are fine though. your cards will show no ill effects. best course of action is to increase your airflow. point a couple high cfm fans right in between those bad boys if possible.
    2600k @ 4.7ghz | Asrock Extreme 3 Gen 3 |
    2 x 4gb GSkill 2133 | Gtx 480 SLI | Crucial M4 + 1tb Storage
    Noctua Nh-c14 | Corsair HX750 | Lanboy Air + lots of fans..
    USA
    18,717
    as daniel mentioned those temps are perfectly fine. If your cards are doing 69 and 79C at load, you have no worries.
    that is actually pretty cool running even for those cards.
    Keep in mind too, the top card is the primary as well, so it should run a bit warmer even when SLI isn't used.
    Intel Core i5 4690K//CM Hyper 212 Evo/2x Akasa Viper R 140mm//EVGA Z87 Stinger//8GB Avexir DDR3 2133MHz//MSI GTX 760 2GB//XFX XTR 550W//Thermaltake Core V21//Win 8.1 64-bit//Seagate ES.3 1TB 128MB Cache 7200RPM, Seagate Barracuda 1TB 64MB Cache 7200RPM
  1. Replies: 6
    Last Post: November 20th, 2011, 03:28 AM
  2. cheapest aftermarket i7 920 cooler
    By adrumm in forum PC Hardware
    Last Post: April 24th, 2009, 09:20 AM
  3. Aftermarket Cooler installation
    By Prince Lalijama in forum PC Hardware
    Last Post: January 8th, 2008, 10:01 PM
  4. MSI K8N Neo4 Platinum (non-sli) Chipset Cooler
    By agathodaimon in forum PC Hardware
    Last Post: June 5th, 2007, 11:42 AM
  5. aftermarket Video card cooler
    By presence06 in forum General Tech Discussion
    Last Post: January 23rd, 2006, 02:47 AM
