Results 1 to 13 of 13
    Question Should a PC power supply work when removed from case and deliver 12V?
    I'm just removed the power supply from an old PC case which was working but when I connect it to a mains plug the fan doesn't even come on
    I was wanting to use it to power an EIDE hard drive to format it
    Jan 2003
    Outside the box
    8,836
    4
    Not without a few tricks How To / Turn ON PC Power Supply WithOut MotherBoard - YouTube
    BTW why can't you just plug it into your existing PSU??
    Be a Liberal, blame everyone else!!
    Thanks for link to YouTube, I'll have a look at it now
    I don't want to plug into existing PC in case I cause a spike so to prevent it, I'd have to power the system down to both attach it and detach it - I assume that is the case??
    Jan 2003
    Outside the box
    8,836
    4
    Not really sure what kind of "spike" you'd be causing? Are you thinking the drive might pull too much power or something?
    Yes, disconnecting a circuit can (I've always believed) casue a surge
    Jan 2003
    Outside the box
    8,836
    4
    You run no greater risk by powering the system down, which you'll have to do no matter what, and adding in the new HDD than doing what you are doing. You have to open the case, find an available IDE/PATA slot and attach the cable no matter the only additional step you are dropping is plugging in the power connector. You shouldn't be breaking an open, powered circuit that might surge anywhere
    Jan 2003
    Milwaukee, WI
    7,657
    Before ANYONE gives anymore advice, we really need to know exactly what your doing and why...
    Your post is confusing and incomplete, and from what little I could glean your going to cause more problems than your hoping to solve..
    If you follow the thread I've created in the technical forum for PC trys to boot, then blue screen, then 2 POST beeps, then reboots in endless cycle you'll see why I'm trying to power up a hard drive
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    All you have to do is get a paper clip and with the main board connector short the green wire with any black wire. This is what I have done.
    Edit- Just watched the YouTube video and dude is doing the same thing.
    Jan 2003
    Outside the box
    8,836
    4
    Yup its a pretty easy trick.
    The OP got things all worked out though. This was related to his other thread amd instead of going through the setup mentioned here he just installed the drive back into the original PC and got things rolling.
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    Gotcha.
    Thanks RicheemxX for not just sorting the problem in the thread referred to, but for a great tip on getting the power supply working. It worked a treat!
    Jan 2003
    Outside the box
    8,836
    4
    No problem, glad you got it all worked out
  1. Power Supply 12V Rail
    By #43 fan in forum General Tech Discussion
    Last Post: June 20th, 2011, 12:29 PM
  2. New Power Supply in Old Case?
    By gyoung in forum Technical Support
    Last Post: February 25th, 2009, 08:23 PM
  3. Power Supply in a TT Case
    By Blenderize in forum PC Hardware
    Last Post: August 15th, 2006, 11:37 PM
  4. 12v power supply for p4
    By termin in forum PC Hardware
    Last Post: September 20th, 2004, 04:47 PM
  5. new power supply? Or new case?
    By islandguy999 in forum PC Hardware
    Last Post: August 26th, 2003, 11:57 PM
