Results 1 to 3 of 3
    need 5v ATA flash card help
    A friend of mine has a behringer ddx3216 digital mixer. http://www.behringer.com/02_products...X3216&lang=eng
    It has an expansion slot for what his manual calls a "5v ata flash card". Ok, I looked at behringers site at a specs pdf and it is a pcmcia slot.
    So now I am trying to find him a ata flash card but I see that there are several types. Mainly type 1 and type 2.
    Which does he need? Is one of them 5v and the other 3.3?
    From my limited knowledge of pcmcia slots I know there are three thicknesses of the cards..so is it possible he could use either a type one OR a type two?
    I dont see anywhere on the behringer site where it states type 1 or type 2...in the spec pdf it just says "pcmcia card slot".
    What do you think??
    Thanks, JP
    Could he use a compact flash card with an adapter? Arent compact flash cards pretty much falling steadily in price?
    JP
    Supporting our military Bill in SD, CA's Avatar
    Oct 2002
    Camelot by the Sea
    10,069
    This is what I use. I have a internal dual slot PCMCIA that I use on my system. The adapter works fine.
    PC Card Adapter For Compact Flash
    Bill
    The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
