Results 1 to 5 of 5
    Ultimate Member mad1's Avatar
    4,766
    reducing case noise
    I want to reduce the noise created by the Thermeltake 6U+ in my case.Has anyone used any type of noise reducing foam inside their case?
    Ultimate Member EvilRick's Avatar
    N of Music City, USA
    7,832
    http://www.techimo.com/forum/t11466.html
    Mar 2002
    US
    28
    Radial Fin Cpu Cooler
    I just ordered a Silent Radial Fin CPU Cooler from QuietPC.com. I can't waite to get that thing in. I've had enough of the hum!
    BTW QuietPC.com has a lot of PC silencing parts...check it out.
    Real gangstas sip on Yacc jkrohn's Avatar
    Suckas-ville
    4,554
    I've used the noise dampening material, said to reduce noise by x decibels. Well, I saw no difference, or heard i should say, but i do have a hole in the side of my case for a 120mm panaflo, so that may be letting more noise escape than i can really block out.
    Signatures blow hard
    Feb 2002
    41
    cheap dynamat 2 10"x10" for 9.99
    heres cheap dynamat check it out
    http://shop.store.yahoo.com/millionbuy/dyn10415.html
